car vibrates after aftermarket wheels..
Old Apr 12, 2004 | 02:46 PM
Johnytang's Avatar
Default car vibrates after aftermarket wheels..
I just put on a set of 16" rims on my 95 integra 2dr. Now my car seems to shake/vibrate when I'm going around 60 - 70 mph. I can feel it in the steering wheel, floorboard, etc. It feels kinda funny at low speeds but it really begins to shake at higher speeds. Could this be because the car is higher now ? and I need to lower it ? I don't think the rims are warped or anything, what could be causing this to happen?
Old Apr 12, 2004 | 02:47 PM
infinatenexus's Avatar
Either your tires aren't balanced, or you have directional tires facing the wrong way.
Old Apr 12, 2004 | 02:48 PM
Grandmasta's Avatar
Are you using hubcentric rings as well?
Old Apr 12, 2004 | 02:49 PM
Johnytang's Avatar
Default Re: (infinatenexus)
how can i tell if they're direction tires ?
Old Apr 12, 2004 | 02:51 PM
Default Re: (Johnytang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnytang &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell if they're direction tires ?</TD></TR></TABLE>
Lokk at the side wall on the tire... it will have a big arrow pointin gin the direction of rotation
Johnytang's Avatar
Default Re: (Grandmasta)
I dont think i have hubcentric rings.. where can i get them from?
trige's Avatar
On my tires there's what looks like an arrow of rotation on the sidewall, you just have to look for it, if it's there you'll find it. Some people can tell by the way the tread looks.
Old Apr 12, 2004 | 02:53 PM
JPineda's Avatar
Default Re: (trige)
I would get your wheels balanced and get an alignment. If this doesn't work, maybe you should get some hubcentric rings.
Old Apr 12, 2004 | 02:54 PM
Johnytang's Avatar
Default Re: (trige)
Thanks guys, I just checked but didnt find any arrows. What would hubcentric rings do ?
They center the rim on the hub
Old Apr 12, 2004 | 02:59 PM
Johnytang's Avatar
Thanks a lot guys, I'm probably going to get an alignment and get the wheels balanced. If that doesnt solve the problem where can I get hubcentric rings?
Old Apr 12, 2004 | 03:07 PM
GSRMON's Avatar
u can find them on Ebay
Old Apr 12, 2004 | 05:18 PM
IVI's Avatar
IVI
Default Re: (GSRMON)
the center rings wont do a damn thing, trust me. the lug nuts will hold the rim in place.. get them balanced. alignment wont help vibrations. vibrations are caused by, out of round tires (slipped belt), bent rims (yours are brand new so probably not), unbalanced or improperly balanced. also dont get them static balanced. if you dont want wheel weights on the outside, get the sticky weights for that side. balancing is cheap.. its about 5 dollars per tire at a local shop.. 10 at a more popular one.
1sick4g63
Aug 25, 2008 04:04 PM
canadianep3
Apr 8, 2008 07:26 PM
UCLA.lion
Apr 12, 2006 07:05 AM
ForceFed Coupe
Dec 11, 2003 06:12 PM
