When you close the CF hood. Do you slam it?
Old Apr 12, 2004 | 11:28 AM
EL'ation's Avatar
Default When you close the CF hood. Do you slam it?
or push gently with your hands?
Old Apr 12, 2004 | 11:31 AM
Jon D's Avatar
Default Re: When you close the CF hood. Do you slam it? (EL'ation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL'ation &raquo;</TD></TR><TR><TD CLASS="quote">or push gently with your hands?</TD></TR></TABLE>
Old Apr 12, 2004 | 11:37 AM
smithenhiven's Avatar
11:11
This is a MUST! A friend of mine had his cf hood cracked by one of those drive trough oil change places when they dropped it shut from being open like 3 feet high.
Old Apr 12, 2004 | 11:38 AM
IS3Fifty's Avatar
Default Re: When you close the CF hood. Do you slam it? (smithenhiven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven &raquo;</TD></TR><TR><TD CLASS="quote">
This is a MUST! A friend of mine had his cf hood cracked by one of those drive trough oil change places when they dropped it shut from being open like 3 feet high. </TD></TR></TABLE>
ouch that sucks. Not to jack the thread, but what part of pittsburgh are you from smith?
Old Apr 12, 2004 | 11:42 AM
11:11
Default Re: When you close the CF hood. Do you slam it? (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">
ouch that sucks. Not to jack the thread, but what part of pittsburgh are you from smith?</TD></TR></TABLE>
A little town called Hopewell, a few miles from the airport.
Old Apr 12, 2004 | 11:59 AM
rusted_eyes's Avatar
Gotta do it this way or risk the chance of cracking your hood.
Old Apr 12, 2004 | 12:11 PM
EL'ation's Avatar
Default Re: When you close the CF hood. Do you slam it? (NA_B16a2)
That's what I did.
The ******* hood won't close.
Old Apr 12, 2004 | 12:15 PM
Jawad.'s Avatar
CF hoods are this weak? how do they withstand front end accidents better then droping it from 3 feet?
Old Apr 12, 2004 | 12:18 PM
cxjon's Avatar
Default Re: When you close the CF hood. Do you slam it? (John Kerry)
is it safe to run with out hood pins?
thinking of picking one up and and have it paint match my car
Old Apr 12, 2004 | 12:26 PM
dori monster's Avatar
Default Re: When you close the CF hood. Do you slam it? (cxjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to run with out hood pins?
thinking of picking one up and and have it paint match my car</TD></TR></TABLE> basically hood pins are to keep the hood from flying up on you when you are driving because the hood is real light and not fitted from factory.
slamming the hood down makes the hood locked for sure, but puts a lot of stress on it.
putting it down and pushing it down with your hands is safer. if it doesnt close by using your hands, just sit on it.
Greasemonkey's Avatar
CF hood are strong but fragile. the CF itself is very strong, but the frame that it use to lay on can be fragile.
I think it's koo lto roam around with no hood pins. I had a CF hood for about 2.5 year and it was kool. I only have hood pins on there because it use to rattle. The pins just kept it down nice and tight.
Old Apr 12, 2004 | 12:36 PM
Filliam H. Muffman's Avatar
Default Re: (Greasemonkey)
Everyone else is wrong.
its pretty easy, just stand in front of your car and hold the hood up with both hands, and then slam it down as hard as you can. if for some reason your hood makes a cracking noise, pop your hood and repeat the process.
Old Apr 12, 2004 | 12:38 PM
Turbo'dMex-A-Keen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John Kerry &raquo;</TD></TR><TR><TD CLASS="quote">CF hoods are this weak? how do they withstand front end accidents better then droping it from 3 feet?</TD></TR></TABLE>
thats what your bumpers and the foam under the bumper covers are for, hoods dont withstand front end collisions!!! man peeps
Turbo Mex
Old Apr 12, 2004 | 12:42 PM
monicle's Avatar
man I dont even slam my stock hood.
Old Apr 12, 2004 | 12:43 PM
H22A EG6's Avatar
Default Re: (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">Everyone else is wrong.
its pretty easy, just stand in front of your car and hold the hood up with both hands, and then slam it down as hard as you can. if for some reason your hood makes a cracking noise, pop your hood and repeat the process. </TD></TR></TABLE>
WHAT NO!!!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey &raquo;</TD></TR><TR><TD CLASS="quote">CF hood are strong but fragile. the CF itself is very strong, but the frame that it use to lay on can be fragile.
I think it's koo lto roam around with no hood pins. I had a CF hood for about 2.5 year and it was kool. I only have hood pins on there because it use to rattle. The pins just kept it down nice and tight.</TD></TR></TABLE>
this is true
the shear strength
and tensil strength
are both very strong shock strenght is not that great
the carbon will crack maby a layer or 2 but that is b/c of the resin being not flexible and too stiff not the carbon
Modified by H22A EG6 at 5:30 PM 4/12/2004
Old Apr 12, 2004 | 02:31 PM
H22A EG6's Avatar
Default Re: (H22A EG6)
oh btw usually the frame is made of glass fibres
glass is much cheaper than carbon so they use it as a frame
it also is not as strong
Old Apr 12, 2004 | 02:35 PM
hatchedzex's Avatar
hey man cf hood never close! the reason is the stock hight of the lactch for your oem hood is low. the carbon fiber latch hook is high.. pop the hood and look at the coupler, there is a way to adjust it easily shouldent take more then 3mins and give it a spray wit some wd40 or some slippry ****.
Old Apr 12, 2004 | 02:47 PM
H22A EG6's Avatar
Default Re: When you close the CF hood. Do you slam it? (hatchedzex)
yea i think i herd somthing about that
being able to move the latch up and down
Old Apr 12, 2004 | 03:45 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL'ation &raquo;</TD></TR><TR><TD CLASS="quote">push gently with your hands?</TD></TR></TABLE>
Old Apr 12, 2004 | 03:52 PM
Ejay Six's Avatar
LMFAO! Hahahaahah
Old Apr 12, 2004 | 04:02 PM
cxjon's Avatar
Default Re: (Ejay Six)
could you coat the area where the the hook is with th resin they use for cf?
Old Apr 12, 2004 | 04:04 PM
hondata04's Avatar
I live in the pittsburg area, my uncle is in a subaru club, they have meets once a month, that would be cool to get a honda/acura meet going....
Old Apr 12, 2004 | 04:09 PM
nerdsports's Avatar
Default Re: When you close the CF hood. Do you slam it? (worlds tallest hung)
i put it down like w/e... and push down on it hard so it locks in the latch.
i've let my hood fall from it being almost vertical and it locked on its own, no cracks... no falling apart.... did sound scary, but nothing happened.
Old Apr 12, 2004 | 05:43 PM
DSR!'s Avatar
Old Apr 12, 2004 | 05:45 PM
DSR!'s Avatar
Default Re: (cxjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon &raquo;</TD></TR><TR><TD CLASS="quote">could you coat the area where the the hook is with th resin they use for cf?</TD></TR></TABLE>
why would you do that??
if ya coat the whole thing it would be hard as a rock and not beable to move
