P/S Fluid?
Do you have to use OEM Honda Power steering fluid, or can I just pick up any brand and toss it in? They say youre "supposed to use ONLY OEM fluid" but if thats the case...why?
TIA!
TIA!
Found this Q&A on Honda PS fluid:
Q. Why must I use Honda brand power steering fluid in my system?
A.The additives formulated into the Honda PSF-S help prevent two crucial areas of concern for steering systems: component wear and oxidation.
Always use Genuine Honda Power Steering Fluid. If it is not available, you may use another steering fluid as an emergency replacement. However, continued use can cause increased wear and poor steering in cold weather. Have the power steering system flushed and refilled with Honda PSF as soon as possible.
I have always heard that if you use a PS fluid other than Honda's it will mess up the PS system seals.
mimog3
Apr 28, 2013 11:38 PM
