differences between the 96 h23 block and 95 h23 block
Old Apr 12, 2004 | 06:34 AM
fastlude69's Avatar
Default differences between the 96 h23 block and 95 h23 block
the only difference is the ecu and dis. right so thats all i would have to change to keep it obd1 right and haver it work
Old Apr 12, 2004 | 07:40 AM
jdmlude_dude's Avatar
Default Re: differences between the 96 h23 block and 95 h23 block (fastlude69)
The crank sensors would need to be removed, injectors will need to be replaced as well as the distributor. Then take your obd1 harness and put it on the motor. Everything will fit up fine.
BoneStckCivic
Oct 21, 2003 02:11 PM
dpreludesi
Feb 17, 2003 02:23 PM
superlude01
Dec 3, 2002 12:49 PM
flip1199
Jun 10, 2002 04:50 PM
