what injectors do i have and what do i run?
i have a 92 hatch with the jdm d15b vtec. are the injectors that came with the motor the motor the ones i need to run, or are the stock dx injectors good, or are they the same. if i went to a b series can i still use these injectors or are the b injectors necesary?
im just asking because the injectors that came with the motor are ******* nasty. Therefore i would NOT like to put nasty parts in my clean engine bay. why be an *** and give a shitty answer. why also swap the injectors if their the same size? do you know if their the same size? if not, do not reply. thanks
I believe that most honda injectors are 240CC. This includes B7, Z6, LS, GSR, ITR...
The Preludes are 320??CC
I think that you'll have no problems using your b7 injectors
jc2801
28
Sep 27, 2013 04:06 AM
