Can I ask you Integra guys a question?
I've tried to get specs on a 93 YS1 transmission but can't seem to find any. All the specs are for GS-R YS1 transmissions. Is it possible that they have the same internals for that year? If not, do any of you guys race all-motor setups with the YS1 non-GSR transmission. Is it a good transmission to use with an all-motor setup? Thanks a lot guys.
the ratio for the long geared ys1 is similar to the hydro LS(S80) tranny. i believe the specs are as follows (from hondalogger)
Long YS1:
1-3.23
2-1.9
3-1.269
4-.966
5-.742
F-4.266
S80:
1-3.23(same)
2-1.9(same)
3-1.269(same)
4-.966(same)
5-.714
F- 4.266 (same)
i do not reccomend the long ratio ys1, same principles as other long ratio gearings
Long YS1:
1-3.23
2-1.9
3-1.269
4-.966
5-.742
F-4.266
S80:
1-3.23(same)
2-1.9(same)
3-1.269(same)
4-.966(same)
5-.714
F- 4.266 (same)
So is it the higher the ratio per gear, the longer the gear is? Or is it the higher the ratio per gear the shorter the gear is? I don't understand that part.
