check engine light on when reverse light wire is conected..???? why..?? 88 crx hf w/ b16
Old Apr 11, 2004 | 07:44 PM
ironchef25's Avatar
Default check engine light on when reverse light wire is conected..???? why..?? 88 crx hf w/ b16
ok its been sometime now since i got my car swaped. every thing is fine. no bog.. no hesitation . motor runs good.. wiring seems to be ok.. but when i got my car swaped. with a b16 i notice that the reverse light wire in the engine(near the o2 sensors) is not conected..? i connected it.. but the check engine light is on.. ask the guy who did my swap about it.. he said that comon with the hf model. just the way the car is wired up. so what i did is just un connected it.. but is there anyway when i can have the reverse light connected and have the check engine light not go on..??
Old Apr 11, 2004 | 09:46 PM
phan's Avatar
Default Re: check engine light on when reverse light wire is conected..???? why..?? 88 crx hf w/ b16 (ironch
what code is it throwing?
Old Apr 11, 2004 | 09:49 PM
Project_ED8's Avatar
lol hey man i had the same problem aloooong time ago when i had this shop do my old b16 swap into my old 88 crx hf. you have to cut some wire from the ecu. only the crx HF's had them and its not required for the b16 swap. its something to do with the reverse lights and hf's. do a search on my old threads you'll find it. hth...
Old Apr 12, 2004 | 05:15 AM
ironchef25's Avatar
Default Re: (Project_ED8)
so what? you just cut it and connect the reverse light and everything will be ok???
Old Apr 12, 2004 | 06:21 AM
jlicrx's Avatar
back-up lights connection to ECU on HF only at ECU pin B9 - green/black wire
Old Apr 12, 2004 | 06:41 AM
ironchef25's Avatar
b9?? i read somewhere thats its b11??
Old Apr 12, 2004 | 06:55 AM
jlicrx's Avatar
B11 is clutch input switch - HF only - green wire
Old Apr 12, 2004 | 07:06 AM
HT Chaplain's Avatar
Loved
i had to do the same thing pull it at the ecu plug i cant remeber which 1 it is though pull 1 and reset you ecu until the problem is fixed its eithier b9 or 11
Old Apr 12, 2004 | 08:38 AM
ironchef25's Avatar
damn where do i get those pins that you use to pull those wire out. i dont want to butcher up my harness
earfejj
May 10, 2011 10:37 AM
hondaex99
Feb 5, 2010 10:34 AM
lsvtecndx
Apr 26, 2009 12:14 PM
niceguy12
Jan 3, 2005 07:01 PM
JohnnieChimpo
Apr 24, 2004 08:27 AM
