Car doesnt start right away when low on gas?
Old Apr 11, 2004 | 07:41 PM
Sergei01's Avatar
Default Car doesnt start right away when low on gas?
Is that possible. Like when for example i have driven over 300 miles, and the niddle is on empty and the yellow light is on. the car if turned off for like 30 minutes or so doesnt start right away. but when the tank is full it fires right up? could that be due that the absense of gas pressure in the tank or the fuel pump not delivering enough fuel into the injectors?
Old Apr 11, 2004 | 07:42 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Car doesnt start right away when low on gas? (Sergei01)
turn the key to the first position and you will here the pump go on and just wait a few seconds and then fire it up.
Old Apr 11, 2004 | 07:43 PM
Sergei01's Avatar
Default Re: Car doesnt start right away when low on gas? (ciRcuitSi y0!)
thanks!
Old Apr 11, 2004 | 07:48 PM
DC4noMore's Avatar
You can try that but the reason it wont start right away is simply because of the lack of gas.
Old Apr 12, 2004 | 05:37 PM
IVI's Avatar
IVI
is this a serious question? your practically asking why wont my car start without gas. when you get that low on gas, your cars practically running on fuel fumes or vapors. which is still combustible. obviously it wont start up just like when its getting proper fuel.. its a good idea not to let your fuel goto the extreme e. because your fuel pump picks up the corrosion and dirt on the floor of your gas tank and clogs up your fuel filter.
Old Apr 12, 2004 | 07:42 PM
..::91TEG-G2::..'s Avatar
Default Re: Car doesnt start right away when low on gas? (IVI)
not sure if this is true or not, but my mom had an old audi 5000s car.. weird thing.. but anyways she ran compleatly out of gas and they told her she had to get her gas lines or system charged up to get the gas flowing through the system again... and that any Fuel Injection car that gets low on gas, needs to have this done.. im thinkin its BS but not sure...
Old Apr 12, 2004 | 07:47 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi y0! &raquo;</TD></TR><TR><TD CLASS="quote">turn the key to the first position and you will here the pump go on and just wait a few seconds and then fire it up.</TD></TR></TABLE>
this works. try it. my civic does it. even when im like 1/4 full sometimes itll do it.
put it in the that first position and let is sit there for a few seconds!
Old Apr 12, 2004 | 10:15 PM
DIY's Avatar
DIY
Default Re: Car doesnt start right away when low on gas? (-iLLuZioN-B18C1)
the old carberated engines.. you run out of gas you must prime your carb with a bit of gas to get it started. as for it not starting right w/o gas...
Old Apr 12, 2004 | 11:30 PM
totalchaos's Avatar
why do u even let the gas gauge get that low? lol i feel back up right b4 i get to a quarter tank of gas
DangercartSi
May 24, 2024 09:07 PM
dan89crxsi
16
Sep 24, 2006 01:22 PM
LvN
Jun 9, 2006 11:31 AM
DC2point0
13
Jul 24, 2005 06:02 PM
garagespecial
Jun 25, 2002 10:00 AM
