auto harness with h22 5spd...need more help
Ok, heres the deal. I swaped my h22a w/5spd tranny into an automatic 92 si. I simply used the auto harness and ran the vtec wires. When we went to start the car, nothing happened. I remembered that i had to make a jumper for the neutral safety switch in order to make it start. I am also using a jdm p13 m/t ecu. The car runs with no problems, well except it will not pass emissions(that is a whole other story), but on the gauge cluster the "drive" indicator light is blinking. There are no reverse lights, no cruise control and i can start the car without pushing in the clutch. I have made a post over this before and someone gave me an auto-manual swap guide for a 5th gen. It helped a little, but still is leaving me blank. Has anyone done an auto-manual swap in a 4th gen? Give me some help techies!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnnytech »</TD></TR><TR><TD CLASS="quote">http://www.csupomona.edu/~jpje...p.pdf
I got this from Josh, hope it helps.</TD></TR></TABLE>
This one has all the info you need.
I used it when I did the swap on my '94.
-Josh
I used it when I did the swap on my '94.-Josh
pr0jektdc2
May 4, 2005 10:01 AM
