FS:>>No More Paper-Clips<< Introducing the (.:: CEL PLUG ::.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0gueSilver_Dc2 »</TD></TR><TR><TD CLASS="quote">wow, great invention!! </TD></TR></TABLE>
its not an invention.. its a honda stock tool / part
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">I'm clueless. Is this an OBD2 thing? </TD></TR></TABLE>
no its the thing that you use to jump the codes, when u get a check engine light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch »</TD></TR><TR><TD CLASS="quote">EG/DC/EK/DA/Preludes from 1992up, and Not so sure about the newer trims</TD></TR></TABLE>
i dont think so, it works with 92-95, 96+ got obd2 and you need a scanner for that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">
i dont think so, it works with 92-95, 96+ got obd2 and you need a scanner for that...</TD></TR></TABLE>
i do it on my 97 civic works just fine. so free bump and right info
DON'T POST INFO YOU HAVE NO CLUE ON!!!!!!!!!!!!
i guarentee this will work on an obd2 honda....I DO IT ALL THE FREAKING TIME!!!!!!
get a clue....don't post wrong info!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
get a clue....don't post wrong info!</TD></TR></TABLE>
i had to use a obdII scanner on 96+ hondas at my job...same with GM, Ford, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9InSPiReD »</TD></TR><TR><TD CLASS="quote">so this plug will get rid of any CEL's?</TD></TR></TABLE>
only if you know how to fix them!
i had to use a obdII scanner on 96+ hondas at my job...same with GM, Ford, etc...</TD></TR></TABLE>
hmmm....well i don't know but i don't need an OBD2 scanner to find the codes on a 96 up honda!!
You should be able to sell this with EASE
