quick flash blinker problem!
Old Apr 11, 2004 | 12:55 PM
TedR719's Avatar
Default quick flash blinker problem!
Anytime I use my left blinker it flashes at a higher rate than normal. Usually it means on of my lights are out but when I check both of the signals where lighting up. Is there anything eles that might cause this problems. This is on a bone stock 94 Civic Dx. Also I notice that the right horn button on the steering wheel does not work.
How do I fix both problems?
Old Apr 11, 2004 | 01:05 PM
DAguyLS's Avatar
Default Re: quick flash blinker problem! (futuresi)
check your spring under your horn button, that fixed mine
Old Apr 11, 2004 | 01:24 PM
JDMlyfestyle's Avatar
check right behind your washer fluid light. there is a little clear box with 6 black wires going to it. see if any of the wires came loose cause that is a ground box. the box should be bolted up. if its not then a wire must be fried
Old Apr 11, 2004 | 01:46 PM
B16Turbo2004's Avatar
yeah, if one of the bulbs arent burnt out just follow the wires, ur bound to find a loose one
Old Apr 11, 2004 | 03:23 PM
Lord Helmet's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">check right behind your washer fluid light. there is a little clear box with 6 black wires going to it. see if any of the wires came loose cause that is a ground box. the box should be bolted up. if its not then a wire must be fried</TD></TR></TABLE>
that and the harness going to the flasher bulb. btw that "clear" box is the chassis ground for all the lighting around that area. I'm betting that is the problem.
I had a problem like that a few weeks ago to my car. the culprit was the chassis ground box not properly mounted down.
Old Apr 11, 2004 | 04:54 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
On my car the right turn signal is faster than the left. How do I fix it so that both signals are fast?
Old Apr 11, 2004 | 06:01 PM
Default Re: (mario82686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario82686 &raquo;</TD></TR><TR><TD CLASS="quote">On my car the right turn signal is faster than the left. How do I fix it so that both signals are fast?</TD></TR></TABLE>
vice versa
Old Apr 18, 2004 | 05:46 PM
bonestock92si's Avatar
Default Re: (sleeperciv)
blinker fluid could be low
Old Apr 20, 2004 | 02:35 PM
TedR719's Avatar
Default Re: (bonestock92si)
Thanks guys I will check it out and let you know what the culprit was.
Old Apr 20, 2004 | 03:39 PM
976's Avatar
976
New User
Default Re: (futuresi)
I bet one bulb is dead or disconnected. The relay amperage is then forced to the remaining bulb(s) on the circuit which makes it blink twice as fast... I hope that made sense...
Old Apr 20, 2004 | 03:59 PM
skunk2eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonestock92si &raquo;</TD></TR><TR><TD CLASS="quote">blinker fluid could be low </TD></TR></TABLE>
classic
yeah my left blinker is fast causing the front corner light not to work. the bulb works but i've found hondas are VERY picky with the wiring. it's prolly just a loose wire
Old Apr 20, 2004 | 05:24 PM
Urban Camo's Avatar
yeah its gotta be a loose wire if it isnt a burnt bulb, but i second the checking of your blinker fliud and while your in the area make sure your muffler fliud isnt low
Old Apr 21, 2004 | 07:02 AM
TedR719's Avatar
Default Re: quick flash blinker problem! (Southtownracing)
you mean muffler bearings!
Old Apr 21, 2004 | 07:10 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futuresi &raquo;</TD></TR><TR><TD CLASS="quote">you mean muffler bearings! </TD></TR></TABLE>
I swear honda makes the WORST muffler bearings...
Old Apr 21, 2004 | 07:17 AM
rxse7n
Guest
Posts: n/a
The horn problem might be your primary horn rotor as well. You should probably call Mr. Wankel who is from Thailand. He is in the yellow pages.
doubleoazn03
Jun 22, 2007 12:48 PM
Mag00n
Honda Motorcycles
Apr 19, 2007 07:58 PM
elmalouno
10
Jul 7, 2004 12:59 PM
kefka
May 22, 2003 11:23 AM
