Honda S2000 Honda S2000
just ran the S2k
Old Apr 11, 2004 | 12:30 PM
civic15.8's Avatar
Default just ran the S2k
60'- 2.41
330- 6.536
1/8- 9.816
MPH- 75.53
1000- 12.594
1/4- 14.965
MPH- 94.97
I dont kreally know what the stock time for a S2k is i've to many didferent times. But someone may know the exact time. But i know i need to work on my 60'. I was launching at 4000 on that run i didnt have much wheel spin and i feathered the clutch a little. Second time i ran i didnt feather it launching at 5000 had a 2.7 60' and ran a 15.7
But does anyone have any tips. I know this would probably help more people out besides me. thnaks in advance.
Old Apr 11, 2004 | 01:24 PM
B18BUUST's Avatar
Default Re: just ran the S2k (civic15.8)
not too shabby!
Old Apr 11, 2004 | 02:14 PM
OC 335i's Avatar
You need practice, that's pretty bad.
What were the track conditions like (weather, altitude, etc.)? What did you launch at? How are your tires?
Old Apr 11, 2004 | 04:08 PM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT &raquo;</TD></TR><TR><TD CLASS="quote">You need practice, that's pretty bad.</TD></TR></TABLE>
Thats being a little too nice...
The s2k is a low 14/high 13 second(if you really know how to drag) car.
Just for a little comparison, the rsx type s runs faster than a 14.9 in stock form. What were other cars on that day running?
Old Apr 11, 2004 | 05:43 PM
Jkan2001's Avatar
I agree with JMS JT, you need practice big time. Also it seems to me like you must be very high elevation. My 91 SER with just cai/header/weight reduction hit 9.5 @ 74.5 mph on street tires and 9.1 @ 94 on slicks.
There was a 2k3 s2000 with intake/exhaust/vafc running consistent 9.3's with 2.1-2.2 60 foots around 76 mph.
Old Apr 11, 2004 | 06:35 PM
civic15.8's Avatar
Default Re: just ran the S2k (StinkyTofu)
yea i know i really need to work on the time but i was really looking for like launch tips or any thing. Once i get going everything is perfect no missing gears or grinding them to death but getting them in gear really fast and good. But launching is what kills me it is the same way in my turbo teg(14.9) launching it was the pits but anymore help will be appreciatted
Old Apr 11, 2004 | 06:40 PM
civic15.8's Avatar
Default Re: just ran the S2k (JMS JT)
What were the track conditions like (weather, altitude, etc.)? What did you launch at? How are your tires?</TD></TR></TABLE>
Tires are fine. i launched at 4000 on my best run. It was about to rain temp. was about 70 degrees and im from alabama so im not high in alititude(dont know exactly)
Old Apr 11, 2004 | 06:46 PM
LSHatch's Avatar
Launch a lot higher than 5000 and slip the hell out of the clutch.
You WILL run faster.
Old Apr 11, 2004 | 06:59 PM
civic15.8's Avatar
Default Re: just ran the S2k (LSHatch)
One guy out there was like launch at 7000 but I dont want to mess this car up
Old Apr 11, 2004 | 07:46 PM
LSHatch's Avatar
I always launch at 7k and still no problems. *knocking on wood*
I was getting 2.0 60's and going 13.7. You can defintely improve big time on the launch. Good luck next time out.
Old Apr 11, 2004 | 07:56 PM
evil vapor's Avatar
what tire pressures were you running?
Old Apr 11, 2004 | 08:12 PM
civic15.8's Avatar
Default Re: just ran the S2k (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">what tire pressures were you running? </TD></TR></TABLE>
30 psi
Old Apr 11, 2004 | 08:26 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic15.8 &raquo;</TD></TR><TR><TD CLASS="quote">
30 psi</TD></TR></TABLE>
might want to try lowering them a tad bit but it seems you weren't having traction issues.
Old Apr 11, 2004 | 08:31 PM
civic15.8's Avatar
alright thanks i think next time il try 6000 rpms if not 7 thanks for the imput guys. I am still up for anymore tips.
Old Apr 12, 2004 | 11:22 AM
Scot's Avatar
those times SUCK DONKEYS!!!!!! Where you launching in snow?
You need more practice....
Old Apr 12, 2004 | 11:42 AM
SpoonSpecR's Avatar
Default Re: just ran the S2k (Scot)
Whoa... 15.7 in an S2000 OUCH! Were you taking off in 3rd gear? Or have an elephant in your trunk? I'm not trying to make you feel bad, but there has to another variable here... Even with your fairly "low" rpm launches you should have done in the mid 14's. Do you have non OE tires? How many miles on the car? ANy mods?
Old Apr 12, 2004 | 12:14 PM
civic15.8's Avatar
Default Re: just ran the S2k (SpoonSpecR)
Yea 15.7 was cause of a bad launch plus I knew that one wasnt going to be as good so I didnt even try after that. But the car only has 11,000 miles on it. And just for the record i know these times SUCK so stop saying that. And there are no mods done.
Old Apr 12, 2004 | 02:42 PM
AllMotorSweepR
Guest
Posts: n/a
if your turbo ls ran the same 1/4 time as your s2k, than you have a problem wiht driving skills. how many lbs are you pushing out on your ls? launch around 6-7k's in the S and just practice a lot more. best way to get faster is to konw how to drive the car.
Old Apr 12, 2004 | 03:08 PM
HONDABOY6903's Avatar
TAKE OFF AROUND 3000 AND LOWER UR TIRE PRESSURE AND GET UP EARLY ONE MORNIN AND PRACTICE ALL DAY
Old Apr 12, 2004 | 04:25 PM
LSHatch's Avatar
Default Re: just ran the S2k (HONDABOY6903)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOY6903 &raquo;</TD></TR><TR><TD CLASS="quote">TAKE OFF AROUND 3000 AND LOWER UR TIRE PRESSURE AND GET UP EARLY ONE MORNIN AND PRACTICE ALL DAY </TD></TR></TABLE>
Please don't post unless the information you contribute is correct and can actually help.
DO NOT LAUNCH AT 3000. End of discussion on that.
LIke I said before civic15.8, launch the car at around 7k if you feel comfortable doing so, slip the hell out of the clutch and just keep the pedal planted. Your times WILL go down significantly.
Old Apr 12, 2004 | 05:35 PM
AllMotorSweepR
Guest
Posts: n/a
slip the hell as in just drop the clutch? or do you mean like feathering it through?
Old Apr 12, 2004 | 05:39 PM
LSHatch's Avatar
Default Re: just ran the S2k (AllMotorSweepR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorSweepR &raquo;</TD></TR><TR><TD CLASS="quote">slip the hell as in just drop the clutch? or do you mean like feathering it through?</TD></TR></TABLE>
Feathering it. It really needs to be feathered hard to run good times and keep it in vtec the whole time.
Old Apr 12, 2004 | 05:42 PM
AllMotorSweepR
Guest
Posts: n/a
so just dropping the clutch from 6.5 lets say isn't going to help out much but if i feather it, it will?i haven't been able to really play around adn test out the feathering method.
Old Apr 12, 2004 | 06:01 PM
civic15.8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorSweepR &raquo;</TD></TR><TR><TD CLASS="quote">if your turbo ls ran the same 1/4 time as your s2k, than you have a problem wiht driving skills. how many lbs are you pushing out on your ls? launch around 6-7k's in the S and just practice a lot more. best way to get faster is to konw how to drive the car. </TD></TR></TABLE>
The only problem I have is launching. Launching is what was also wrong with my teg. 7 psi is what im runing. And next time I go to the track I will try the 7 grand launch. And yes I know I need to practice. Thanks alot lshatch and the rest of you, you have really helped.
Old Apr 12, 2004 | 06:18 PM
LSHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorSweepR &raquo;</TD></TR><TR><TD CLASS="quote">so just dropping the clutch from 6.5 lets say isn't going to help out much but if i feather it, it will?i haven't been able to really play around adn test out the feathering method.</TD></TR></TABLE>
Dropping the clutch will most likely either:
If you get traction- destroy the rear or just bog off the line. It will jump hard, but then just drop.
Or you may just spin.
Feathering it, will keep it at 6500 or whatever you launch at, at all times, keeping the car in vtec and keeping it in power at all times. Just practice it at the track, as the car launches much differently on the street.
