eletric prob!!! so simple that ir is not!
Old Apr 11, 2004 | 11:54 AM
H22A EG6's Avatar
Default eletric prob!!! so simple that ir is not!
https://honda-tech.com/zerothread?id=829300
Old Apr 11, 2004 | 03:55 PM
H22A EG6's Avatar
Default Re: eletric prob!!! so simple that ir is not! (H22A EG6)
can no one help me????
Old Apr 11, 2004 | 10:33 PM
LSP's Avatar
LSP
need more info.. i saw your other thread..it didnt tell me squat. How did you hook up the tach? what does the tail lights have to do with it? did you do some "custom" wiring on your tail lights as well? The tach is turning on and off intermittently? what i need to know is, where did you hook up the tach's light wire to? directly to a light wire? fuse box terminal? if its cutting in and out, and fuse is ok, that leads me to think theres a loose wire or connection somewhere in there.
Old Apr 12, 2004 | 07:23 AM
H22A EG6's Avatar
Default Re: eletric prob!!! so simple that ir is not! (LSP)
ok
i wedged the wire for the light on the tach in the fuse
now there is no power going through that fuse so the tach will not light up
so i put the tach in with a nother fuse and now the tach ligh works fine
but every thing going to what i belive is fuse #19 (taillights acc lights and corner lights) does not work
i replaced the fuse with a good working one and still nothing works
that leads me to belive that it is not the fuse
so does any one know what happened???
Old Apr 12, 2004 | 10:26 AM
rjr162's Avatar
check your other thread
ilovemydc5
Sep 14, 2010 07:40 PM
Dc2 Powered
Oct 18, 2009 02:17 AM
.Slug
Oct 29, 2006 10:04 AM
booja
Sep 7, 2004 10:20 AM
