insturment cluster bezel removal
I am removing the bezel on my 93 teg. I know about the obvious two screws above the insturment cluster, but I feel there is more over near the temp control area because I can't get it loose. Is there more over there? Where?
kickdown
Theres only two. You need to pull hard to get it off. What I do is stick my finger between the black plastic and your dash, then pull slowly but steady. Once you get it off you'll know why its tricky.
[Modified by LostGsr, 5:16 PM 10/27/2001]
Actually I got it off. Its a 93 and its one piece w/ includes the a/c controls etc. There are 4 screws to remove. Two above the gauges, one below the steering wheel on the rh side and one to the far right by the vent buttons hidden under a small square coverpiece. Thanks for responding tho.
kickdown
redsidriver
Feb 13, 2007 11:42 AM
Perfectionist
Dec 2, 2006 12:52 PM
illcypher187
Sep 24, 2004 08:18 PM
