Does Installing 5-lug require new axles?
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Built »</TD></TR><TR><TD CLASS="quote">If its a usdm 5 lug than you can use your current axels but if its a JDM 5-lug you will need 36mm axles</TD></TR></TABLE>
USDM ITR and JDM CTR use a 26 outer spline axle with a 32 mm nut.
same as GSR 26 spline, 32 mm nut
+98 JDM ITR uses 28 spline outer axles with a 36mm nut.
SlammedDC2teg
Aug 16, 2005 06:41 PM
jdmjohn02
Jan 11, 2004 07:56 PM
oem
Jan 27, 2003 08:54 PM
