FS: 99 Civic Si B20vtec Turbo 400whp+
Old Apr 11, 2004 | 07:12 AM
99B16Si's Avatar
Default FS: 99 Civic Si B20vtec Turbo 400whp+
1999 Civic Si Fully Built B20/VTEC Turbo w/less than 5,000 miles on fully built motor.
$12,300
TURBO KIT:
Turbonetics T3/T4E60-1 .63A/R stage 3 wheel w/ less than 8k miles.Revhard manifold,tial 35mm wastegate,greddy typeS BOV,3" stainless intake pipe w/ hks filter,XS engineering 26x10x3intercooler.Stainless 2.5"Downpipe w/ extra bung
BLOCK:
B18A1 block sleeved by Golden Eagle Mfg. to 84mm.CP sanded top 9:1 pistons,eagle rods,ARP rod bolts/headstuds,new ITR oil/water pump,honda bearings,seals,gaskets,b20 headgasket. micropolished factory LS crankshaft. endyn crankcase breather kit
HEAD:
B16a head.ITR valve cover,skunk2 valve springs/retainers. skunk2 intake manifold,GSR cams,new plug wires,cap/rotor,ngk plugs.
TRANNY:
Flawless GSR Tranny,ACT XT pressure plate,ACT 6puck disk,short shifter,shifter bushings.
FUEL MANAGEMENT:
Uberdata engine management. 3 bar MAP sensor,Defi 880cc(84lb) injectors,walbro255lph fuel pump,new fuel filter,B&M fuel press gauge, vortech fuel rail and adjustable fuel pressure regulator.
SUSPENSION:
Koni adjustables,ground control coilovers,ITR strut bar,ingalls front/rear camber kit. factory Si front/rear sway bars
INTERIOR:
extremely clean factory Si interior. dual gauge bezel w/ autometer boost/oil pressure,real ITR shift ****,greddy profecB boost controller.
MISC:
falken azenis front tires(20%),half tread rear, powerslot front rotors w/ AEM brake pads, factory rear rotors w/ AEM pads. open downpipe. energy suspension motor mount inserts.all new belts,stock radiator,slim fan,jackson racing 160 deg thermostat.
car is driven daily to school and work and drives perfect,has never been wrecked,does not overheat,smoke(other than fuel)or burn any oil. the car produced 395hp and 295tq to the wheels @20psi on pump gas!!! everything the car came w/ is fully fuctional.motor is capable of over 500 horsepower to the wheels w/ race fuel without breaking a sweat.
only thing the car needs is new front bumper because mine has a decent sized scuff on it.
it doesnt come with a couple things shown in the pictures. no exhaust, no leather front seats, and no fluidyne radiator
Modified by 99B16Si at 11:54 AM 6/25/2004
Modified by 99B16Si at 11:29 AM 6/26/2004
Old Apr 11, 2004 | 07:13 AM
99B16Si's Avatar
Modified by 99B16Si at 8:17 PM 4/17/2004
Old Apr 11, 2004 | 10:12 AM
TheNasty0ne's Avatar
Default Re: FS: 99 Civic Si B20vtec Turbo 400whp+ (99B16Si)
Wheres the B20?..
I only see a B20 Head Gasket...lol
Nice car tho
Old Apr 11, 2004 | 03:40 PM
99B16Si's Avatar
ls sleeved to 84mm=b20
Old Apr 12, 2004 | 09:31 AM
alpha's Avatar
This is a very clean Si chassis. All the right parts were used and the build is fairly new. Bump for an honest HT member.
Old Apr 12, 2004 | 10:45 AM
SiRkid's Avatar
beauty!
sad to see it go
Old Apr 12, 2004 | 12:45 PM
99B16Si's Avatar
ttt
Old Apr 14, 2004 | 09:56 PM
b16hybridsol's Avatar
Default Re: (99B16Si)
wish i was in flordia, i'd trade my h22 turbo teg in a heartbeat for that
Old Apr 14, 2004 | 10:06 PM
oem_dc2's Avatar
Default Re: (b16hybridsol)
that thing is a munster bump
Old Apr 15, 2004 | 07:30 AM
photec2's Avatar
Default Re: (projectturbo)
you got dyno sheetzzzz
Old Apr 15, 2004 | 09:15 AM
99B16Si's Avatar
yea ill post it up later
Old Apr 17, 2004 | 04:19 PM
99B16Si's Avatar
ttt, i cant get the dyno graph off the disk
Old Apr 17, 2004 | 04:23 PM
97Civic-R's Avatar
badass car..free bump for reppin tampa
Old Apr 18, 2004 | 10:27 AM
99B16Si's Avatar
ttt
Old Apr 18, 2004 | 11:37 AM
one.simple.da's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">ls sleeved to 84mm=b20</TD></TR></TABLE>
ls sleeved to 84mm = 2.0 LS, not a b20.
Old Apr 18, 2004 | 03:47 PM
99B16Si's Avatar
Default Re: (JDMSaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSaint &raquo;</TD></TR><TR><TD CLASS="quote">ls sleeved to 84mm = 2.0 LS, not a b20.</TD></TR></TABLE>
whatever man, go away you=moron
ttt
Old Apr 18, 2004 | 03:55 PM
alpha's Avatar
A steal for the price
Old Apr 18, 2004 | 04:45 PM
Derek14's Avatar
ttt</TD></TR></TABLE>
Well, he did have a 100% true point.... needless to say, clean car
Old Apr 19, 2004 | 06:36 AM
99B16Si's Avatar
jeez...ttt
Old Apr 19, 2004 | 06:41 AM
VTECisSeXY's Avatar
*insert here*
all b20's are a ls bored... to the best of my knowledge atleast.
free bump for a hawt car. good luck
Old Apr 20, 2004 | 08:02 AM
99B16Si's Avatar
ttt
Old Apr 20, 2004 | 02:35 PM
tilt.'s Avatar
BUMP for a clean car and a good seller, bought my rods from him.
Old Apr 20, 2004 | 02:59 PM
99B16Si's Avatar
thanks
Old Apr 21, 2004 | 03:23 AM
alpha's Avatar
To the top. Dave, try putting this on The Parts Trader too.
Old Apr 21, 2004 | 06:43 AM
azn6915's Avatar
nice car very clean
