87 crx si keeps Stalling
Old Apr 11, 2004 | 01:33 AM
Kaedachef's Avatar
Default 87 crx si keeps Stalling
i have a 87 crx si with pgm-fi and my car heats pretty quick and will stall when my temp gauge reads 1/3 and i usually have to wait like 15-40 min to start it again, and my car has trouble on the cold start sometimes and if i start it and turn it off it usually wont start for like 15 min. When it dies it wont pop start so can anyone tell me exactly what is wrong with my car.
also - my pgmfi light is usually comes on when i start it and if i dont hear da buzzing noise it wont start and my pgmfi light comes on after 2 min of driving.
Modified by Kaedachef at 5:16 PM 4/11/2004
Old Apr 11, 2004 | 08:17 AM
Kaedachef's Avatar
Default Re: 87 crx si keeps Stalling (Kaedachef)
can anyone help me!
Old Apr 11, 2004 | 08:22 AM
kron0ne's Avatar
do a tune up.. plugs wires cap and rotor, keep in mind that honda ignition systems suck
Greg S.
Old Apr 11, 2004 | 08:39 AM
Kaedachef's Avatar
Default Re: 87 crx si keeps Stalling (lsi crx)
I did all that myself, and the problem was here since before I did that, which is why I'm clueless. Any other suggestions?
Old Apr 11, 2004 | 08:41 AM
blah13's Avatar
Once it dies and wont start, start finding out why. Check for spark and fuel, you know its timing is ok, and has has compressio since it will run. I'd be willing to bet your having trouble with your spark. Sorry I cant help more with specifics but I dont know much about that gen. Good luck.
Old Apr 11, 2004 | 08:43 AM
StupidSlowRSX's Avatar
Default Re: 87 crx si keeps Stalling (blah13)
Actually that sounds more like a sensor
Old Apr 11, 2004 | 08:46 AM
Kaedachef's Avatar
Default Re: 87 crx si keeps Stalling (StupidSlowCRX)
StupidSlowCRX,
the thermostat sensor?
Old Apr 11, 2004 | 08:53 AM
Wouldnt suprise me. Obviously what ever it is, malfunctions once its warmed up and wont operate correctly again until its cooled back down. So something in the thermostat could be a major possibility, Try searching around you intake mana as well, and exhaust mana.
Any codes?
Old Apr 11, 2004 | 08:55 AM
ahh, i see you added that intresting part about the MPFI..
Check your Crank angle sensor
Old Apr 11, 2004 | 09:07 AM
crxdave's Avatar
had a similar prob with my 91 DX was the crank angle sensor for me which was in the dist had to get a new dist
Old Apr 13, 2004 | 08:20 PM
Kaedachef's Avatar
Default Re: 87 crx si keeps Stalling (crxdave)
what does a crank angle sensor look like?
Old Apr 16, 2004 | 10:57 PM
Kaedachef's Avatar
no1s got da answer
Old Apr 19, 2004 | 07:46 PM
Kaedachef's Avatar
bump
Old Apr 19, 2004 | 09:05 PM
civickiller's Avatar
idk about the 87 rexs but in the newer engines its in the crank, but idk about pre 88.
Old Apr 20, 2004 | 07:55 AM
crxfanatic's Avatar
New User
I'd look at the main fuel relay as a culprit.
What code are you throwing???
lukehonda
Aug 4, 2011 03:36 PM
NorCalCJ
May 2, 2006 09:15 PM
crj_lll
Feb 15, 2006 06:48 PM
vtecn8ive
21
Nov 5, 2005 09:35 AM
rhl487
Sep 17, 2004 11:53 PM
