Stumped on problem on crx... help need plz
when i drive down the road, i can apply slight pressure on the gas pedal, and the car will studder for a few seconds, then it will catch and pull ... i replaced the spark plugs and distrib cap and wires. any ideas?
how is the car running thats the question
Code 1 O2 sensor (this could be the problem)
Code 7 TPS (this makes your car run like **** with this light)
code 17 VSS (this is fine, i get this code daily)
code 20 ELD (do a search, this is ok to have )
so yeah.. broke it down for ya.. have fun
code 7, hmm bad TPS or not connected properly. What's the motor and ECU in your rex??? your ecu should be code free.
I had the same problem, its your o2 sonsor, your car runs rich when you throw a cel and its code 1, it runs in a "limp" mode and dumps more fuel then nessary. -Ben
ok...
motor is a hf, with si eccu ( didnt do it prev owner did) i figured out whut it was...
my distribby came loose from the screws and i guess messed up my timing. damn i need a timing gun..
1_SC_GSR
Aug 14, 2006 10:24 PM
sickvtec
May 25, 2006 06:58 PM
c for sea
12
Oct 22, 2004 04:52 PM
