Skunk cams.....good or bad???? for N20?
what kinda gains from cams??? does anybody have dyno charts for camshafts, mainly skunk stage 1,2? and is it possible to just change the intake camshaft?
skunk2 stage 2 is about 17whp gain
skunk2 stage 1 is ok on stock valvetrain
skunk2 stage 2 and higher u need to have the valvetrain changed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">here is thae edrunk bastards epinion, if you spray on bg= cams alot i s gonnna leave the lcylinder, yet still makeking it fgo fster........ due to the overlap ofr what eh hell hever .....by tuning the overlap out it will slow the car down because your loosin g the cams prpbabliltiyt. so throw mro e juice into it and get a better resulet............ my boy had crowers 2's and aa 75 shot wthg a hot *** bottle and it wasw fukin nastt</TD></TR></TABLE> Put down the keyboard and get some sleep.....Drink the biggest glass of water you can before you hit the sack
is it possible to run skunk stage 2 cams on a stock valvetrain? also, are there any gains in just upgrading the Intake cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries »</TD></TR><TR><TD CLASS="quote">is it possible to run skunk stage 2 cams on a stock valvetrain? also, are there any gains in just upgrading the Intake cam?</TD></TR></TABLE> Yeah it's possible, but it wouldn't last more then a few seconds above 6,000 rpms....As far as just upgrading the intake cam, I hear about people doing jut the intake cam using either an ITR or CTR intake cam.But why not do them both at the same time you can only take so much air in if you can only get so much out
Oh with SKunk2 Stage2 cams on stock valve springs and retainers you'd make power over/under 6k rpms for a few seconds before your stock valve springs and retainers failed and trashed you head and destroyed your bottom end..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries »</TD></TR><TR><TD CLASS="quote">ok so i guess stage 2 is definitely out of the question...! thanks bro
</TD></TR></TABLE> Dude, I would toattally recomend getting them.. Just get a good set of valve springs and retianers... The Vtec Croosover with them is insanely loud, people take notice when they hear it!
what is the price range for upgrading springs, retainers....? maybe ball park? Im running a b18c1 hittin 13.8's all motor, and 13.0 with a little n20. i wanna be in mid 12's with n20. you're right about screamin vtec! Its pretty loud now, but the louder the better.
skunk2 stage 2 + full skunk2 valvetrain = badass vtec x-over
just save serious i would not ask for any better cams on a car daily driven
intake cam is usually CTR if u wanna do it
I think price skunk2 stage 2 and full valve train, adjustments, and install maybe 1300-1500
just a guess stage 2 cams run about 700-900
You als need to add in the price of some sort of vafc/Hondata to ajust the vtec crossover and fuel maps to get those stage 2's to run correctly
http://www.inlinefour.com/salskunvalsp.html
there is a spring/retainer special on inlinefour.com. thats a real good price
Sik is right. and yet again Inlinefour has a special on guides and valves:
http://www.inlinefour.com/salskunracva.html
i fig when u do the valves and stuff u just count on dropping an assload of cash and just to cams, valvetrain, tuned pnp, and the whole bit if the head is off the engine might as well get it all done IMO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C »</TD></TR><TR><TD CLASS="quote">you can run Skunk stage 2's on Stock Type R spings and retainers with RM inners.
PM rocket
u can and u also can run your car for 15K miles without a oil change or u can run your engine on 3 cyclinders the point is u r not supposed to skunk2 recommends their full valvetrain on stage 2 and up stage 1 u can run anything
PM rocket
</TD></TR></TABLE>u can and u also can run your car for 15K miles without a oil change or u can run your engine on 3 cyclinders the point is u r not supposed to skunk2 recommends their full valvetrain on stage 2 and up stage 1 u can run anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic »</TD></TR><TR><TD CLASS="quote">skunk2 recommends their full valvetrain on stage 2 and up stage 1 u can run anything</TD></TR></TABLE>
prolly cuz they want to make money.
i'm 99% Rocket said that valvetrain can handle that cam.
i'm 99% Rocket said that valvetrain can handle that cam.</TD></TR></TABLE>
it can handle it put its not the ideal parts matched, yes they wanna make money, but they have quality parts to match together which is great
Mr.Milton
Mar 29, 2008 06:01 PM
tone*def
Jun 14, 2004 01:21 PM
