Zc swap is in and throwing a code 6.
Old Apr 10, 2004 | 09:23 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default Zc swap is in and throwing a code 6.
im stoked that my zc swap is in but its throwing a code 6--coolant temperature. im also noticing that the radiator fan is not turning on even though the motor seems to be getting really hot and the temperature guage is at normal. im guessing there is an error in our wiring. what do you guys think?
Old Apr 10, 2004 | 10:40 PM
Default Re: Zc swap is in and throwing a code 6. (iluvjasmine)
Old Apr 11, 2004 | 08:56 AM
Old Apr 11, 2004 | 09:45 AM
EG8R's Avatar
Make sure the sensor is plugged in....
Change the sensor with the one from your old engine....
Old Apr 11, 2004 | 11:33 AM
newaccordguy2003's Avatar
i'd also check the fuses. my friends ef with a ZC swap had this same problem, and it turned out to be a fuse. good luck.
Old Apr 12, 2004 | 09:55 PM
Default Re: (newaccordguy2003)
where is the coolant temperature sensor on the zc block?
Old Apr 13, 2004 | 06:31 AM
jlicrx's Avatar
Default Re: (iluvjasmine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvjasmine &raquo;</TD></TR><TR><TD CLASS="quote">where is the coolant temperature sensor on the zc block?</TD></TR></TABLE>
there are 3 coolant temperature sensors on the engine - 2 in the end of the head, just below the distributor - one for the gauge which is one wire (yellow/green) connector - one for the ECU (which gives you code 6) which is 2 wire (red/white & green/white) - one on the back of the block next to the oil filter which turns on the cooling fan, has 2 wire connector (yellow/green & black)
minime-dom
Apr 30, 2009 12:19 PM
coreyfrenzel
Apr 5, 2006 08:43 AM
Idiotboy
Jul 30, 2005 11:37 AM
Pcart
Oct 17, 2002 05:59 AM
