ok ok doing the h22
Old Apr 10, 2004 | 09:11 PM
streetspeed607's Avatar
Default ok ok doing the h22
you guys convinced me lol if a buy a h22 long block
[URLhttp://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30026][/URL]
what else would i need, the tranny or can i use my lx 5speed tranny? then i would need the p13 ecu correct? anything else or is that it?
also can the accord be made a decent drag car. i want to run low 14s, is it possible with a NA h22 in a 91 4door accord??
Old Apr 10, 2004 | 09:26 PM
Nick H's Avatar
New User
Default Re: ok ok doing the h22 (wagon)
if you buy the longblock from h motors online, you will need the following:
-p13 ecu (or whatever modified ecu that you wish to use)
-prelude driverside motor mount (grind down the edges to make it fit)
-exhaust manifold, as the hmotors long blocks only come with the top section of the header)
-whatever sensors do not come on the motor (tps, map etc)
also, you can use your 5 speed lx tranny...it will bolt straight up...and, a mistake i made, go ahead and get an aftermarket clutch and flywheel while you are at it...you will regret it if you don't, and it's a pain to go back in and do it at a later date...get the wiring instructions from a website like h22a.org or whatnot, and you'll be good to go...
Old Apr 10, 2004 | 09:48 PM
thanx for ur reply.
Old Apr 14, 2004 | 10:37 AM
jonjon149's Avatar
Default Re: ok ok doing the h22 (Nick H)
Who else has the wiring instructions for this swap h22a.org is down
Raven_Accord
Jun 10, 2007 03:42 PM
slow_yota
Aug 28, 2004 06:11 PM
SpeedFreak77
Aug 17, 2004 10:46 AM
kentucky accord
Jun 9, 2003 05:57 PM
screamer7
Jul 23, 2001 11:46 PM
