shift linkage
Old Apr 10, 2004 | 09:11 PM
drewek-9's Avatar
Default shift linkage
ok so how do i remove an shift linkage bar on the tranny chiton and heynes both say to pust the pin out how do i and where can i get another one from ????? motor is an sohc ex motor
thanks
drew
speedNmotion
so cal
Old Apr 10, 2004 | 09:59 PM
Sketch_hs's Avatar
Default Re: shift linkage (civichbturbo2000)
8mm punch man, best way.
line the punch up with the pin and tap it out with a hammer. you can prob reuse the pin but otherwise you'll want to order one OEM from honda. DO NOT USE A BOLT!
Good luck!
Old Apr 10, 2004 | 10:24 PM
drewek-9's Avatar
Default Re: shift linkage (Sketch_hs)
THANKS YO
Old Apr 11, 2004 | 12:25 AM
T.J.'s Avatar
just remove it with a punch, I didnt have that was the right size so i just cut one i had with a dremmel to make a perfect fit.
Old Apr 11, 2004 | 12:29 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: shift linkage (Cake-boy)
what they said above. also a lot of people have said that jamming a screwdriver in there will not work most of the time.
Old Apr 11, 2004 | 12:31 AM
=GAME='s Avatar
the infamous bitch pin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">8mm punch man, best way.
Good luck!</TD></TR></TABLE>
Old Apr 11, 2004 | 07:28 AM
Rob!'s Avatar
Default Re: shift linkage (=GAMEOVA=)
its so funny when you go to look at a swap for sale...you see that part of the linkage still on the tranny because people dont know how to take it off so they just cut it off haha...
Old Apr 11, 2004 | 08:19 AM
Slopoke's Avatar
Default Re: shift linkage (EKsnatchback)
If you have access to air tools. An air hammer will replace it in 2 seconds.
Otherwise, use the punch or a long 8mm bolt.
Old Apr 11, 2004 | 08:34 AM
Ryan C's Avatar
Default Re: shift linkage (Slopoke)
took me an hour plus to figure this out back in the day.
but now they come out in a snap for me
Old Apr 11, 2004 | 10:33 AM
zer0.'s Avatar
i hate that damn pin! like posted earlier DO NOT USE A BOLT.
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
taking-back-sunday07
24
Feb 28, 2007 02:09 PM
TEG777
Jul 21, 2005 01:12 AM
stegon78
Jun 24, 2005 08:46 AM
sabertooth
Jan 9, 2004 10:23 PM
