new clutch?
Old Apr 10, 2004 | 08:33 PM
rough_draft's Avatar
Default new clutch?
I'm trying to figure out if i need a new clutch on my 95 gsr or not. It has 103k miles on her.. It's kinda hard to get her into first and 2nd gear even when the clutch is in.. it isn't forcing but it isn'y gliding.. it's noticable and i'm starting to get worried. it started today, would it help to puit in synthentic oil in my tranny? i've heard that makes it shift a lot lot smoother.. if i do need a clutch, any suggestions?? Thanks
Old Apr 10, 2004 | 09:20 PM
mrmonk's Avatar
Default Re: new clutch? (rough_draft)
Do you know if your are still ride on the original clutch or has it been replaced? Also are there any click or squeaking sounds comming from the clutch when you disengage it? we need some more info to help you out try to be alittle more descriptive.
Old Apr 10, 2004 | 11:01 PM
i think it's stock clutch.. an old lady had it before and drove it great, nice and slow but i've stepped her down a lot a couple of nights...i dont think there is any clicks or sqeakin noises.. but i noticed i had to slow down more to put it in first gear..ty
Old Apr 10, 2004 | 11:09 PM
xplanetearth420x's Avatar
Default Re: (rough_draft)
same thing happen to me i have to go slower to put it into first also
Old Apr 11, 2004 | 07:12 AM
boostmywankle's Avatar
Default Re: (xplanetearth420x)
yeah me tooo... its probley from smoking my damn tires.....damn stock clutch
Old Apr 11, 2004 | 07:22 AM
Ditdogs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft &raquo;</TD></TR><TR><TD CLASS="quote">i think it's stock clutch.. an old lady had it before and drove it great, nice and slow but i've stepped her down a lot a couple of nights...i dont think there is any clicks or sqeakin noises.. but i noticed i had to slow down more to put it in first gear..ty</TD></TR></TABLE>
to the old lady for knowing how to drive a 5 speed!
Old Apr 11, 2004 | 12:16 PM
lol rgr.. think i should just put syntehtic tranny fluid in her and see how she shifts?? Thanks
Old Apr 11, 2004 | 03:03 PM
crawdad689's Avatar
is there much more play in the pedal as well?
if so, you probably just need a new clutch master/slave cylinder
Old Apr 11, 2004 | 03:47 PM
IntEGNYC's Avatar
Default Re: (crawdad689)
you can check if you need a clutch replacement by seeing where the bite point on the clutch pedal is. If its fairly low, you may need it changed...
but before going there, check your clutch fluid. it may be low, or you may have air in the line. I had thought i needed a clutch change until i realized my slave cylinder had a slow leak...
at 92k, im still on the original clutch doing just fine... Just had to replace the slave cylinder. the cylinder cost about $39 and cost me $60 in total to replace. it was a 15 minute job.
Old Apr 11, 2004 | 07:56 PM
nice, how can i check my fluid and such? sorry if i'm a noob.. any DIY's on the slave cylidner.. should i just go ahead and replace it? i just hit 104k miles.. Thanks
Leo95SE
Aug 18, 2002 07:17 PM
pr0digy1
Apr 18, 2002 09:59 AM
Accord_Munch
Dec 17, 2001 12:33 PM
Silude93
Oct 30, 2001 03:30 AM
