4 speed civic what is this
Old Apr 10, 2004 | 08:19 PM
Honda4Life723's Avatar
Default 4 speed civic what is this
i bought a 89 civic 1.5 dual point (Vin 2HGED) and it has a four speed what is this all about can i use it on other cars is it ne better what the down low on this trans.
Thanks alot.
Old Apr 10, 2004 | 08:28 PM
Default Re: 4 speed civic what is this (Honda4Life723)
Dose ney one ever heard of this help please
Old Apr 10, 2004 | 08:32 PM
CRneXt's Avatar
Basically you have a 5 speed transmission minus the overdrive...
Overdrive is great for highway driving... I think these transmissions were just mainly intended for around towning...
Yes, it will work on other cars with the D series engine. WHy would you want to? In a bind or desperation I suppose. I would rather have the 5 speed.
I have another 4 speed if you would like to pay shipping for it.
Matter of fact, I have a lot of D series stuff...
Scott
Old Apr 10, 2004 | 08:41 PM
Default Re: 4 speed civic what is this (CRneXt)
ok so for drag strip racing a 4 speed would be better but are the ratios the same as the normale 5 speed that i have for the d serise engines
thanks
Old Apr 10, 2004 | 10:17 PM
JohnnyLux's Avatar
the ratios are different in the 5 spd than the 4 the 5 has shorter gears. when i had my 4 spd in second i could hit 60mph but with my 5 spd i hit the rev limiter @ like 55-56mph (i dont have a tach so i have to rely on my speedometer and noise from the engine)
Old Apr 10, 2004 | 10:52 PM
Louie B.'s Avatar
Std 4sp 1st gear ~= Si 5sp 1st
Std 4sp 4th gear ~= Si 5sp 5th
In a normal Honda engine where you need to keep the rpms up the Si 5sp is a much better choice.
I have heard of some turbo'd guys using the 4sp trans in order to keep the turbo spooled for a longer period of time.
Wanza
12
Jun 19, 2009 12:42 PM
b_serious
Acura TSX
Dec 7, 2005 08:42 AM
drinksoy
31
Jul 11, 2004 03:25 PM
GQ
Mar 18, 2004 07:36 PM
Floyd
Nov 14, 2003 08:19 PM
