How many o2 sensors does an 01 ITR have
How many o2 sensors does an 01 ITR have...I have a JDM DC 4-1 header and a JDM ITR cat...the cat does not have the spot for an o2 sensor but the header does...any suggestions??? oh yeah its pheonix yellow if that helps j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil DOHC »</TD></TR><TR><TD CLASS="quote">Ditto, primary o2 on the header and secondary o2 on the cat.
EVIL </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg »</TD></TR><TR><TD CLASS="quote">can i drill a hole for the secondary o2 into the jdm ITR cat..any suggestions</TD></TR></TABLE>
if you are running a jdm ecu you don't even need to worry about the 2nd o2 sensor since the ecu will not throw a code if it is missing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* »</TD></TR><TR><TD CLASS="quote">
if you are running a jdm ecu you don't even need to worry about the 2nd o2 sensor since the ecu will not throw a code if it is missing.</TD></TR></TABLE>
Not only that....but when I installed my header and was running two o2 sensors the car actually wouldnt start. JDM only recognizes 1 and the second one was faulting the computer. Anybody else had this happen before. May have just been a coincidence but when we took it out it started right up!
Modified by B18C-Rsi at 2:20 PM 4/16/2004
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy »</TD></TR><TR><TD CLASS="quote">
hammer says chill man!</TD></TR></TABLE>
HOTNESS
HOTNESS
Gump
Jul 26, 2004 08:45 AM
