Taking out A/C for drag
Old Apr 10, 2004 | 05:34 PM
PrimeXample's Avatar
Default Taking out A/C for drag
Has anyone taken out their A/C for drag racing? I've been told it gives around 10ft Lbs. If you have taken it out please explain how it worked for you.
Old Apr 10, 2004 | 05:36 PM
Kendall's Avatar
The A/C will have minimal effect on power due to the fact that when it's not operating, it doesn't cause hardly any resistance anyway. The primary reason most people remove it is for the weight savings.
Old Apr 10, 2004 | 05:45 PM
Default Re: Taking out A/C for drag (PrimeXample)
I'm just starting out at this drag strip here in San Diego and I'm looking for every advangtage I can get. I've got a 99 Integra LS with AEM V2 CAI, DC 4-2-1 headers, and when I race I use a test pipe. Do you think the A/C will help with since I've got next to nothing on the car?
Old Apr 10, 2004 | 05:47 PM
Kendall's Avatar
It won't make a difference noticable enough to justify removing the system. Being that you're just starting out, you should focus on dialing in the run and getting your 60 foot times as low as possible.
Old Apr 10, 2004 | 05:51 PM
Default Re: (Kendall)
When I race I take off my power steering belt and it gives a little more throttle response, is it now true that the A/C will be similar?
Old Apr 10, 2004 | 05:54 PM
Danger's Avatar
Default Re: (PrimeXample)
i doubt you would feel any differnce from removing the AC unit . its starting to get hot , im sure it will come in handy .
Old Apr 10, 2004 | 05:55 PM
Kendall's Avatar
No, being that there is only resistance in the A/C pulley when the system is operating the resistance of just a belt spinning a free spinning pulley will be virtually nothing. I would try to find speed elsewhere.
Old Apr 10, 2004 | 10:44 PM
xplanetearth420x's Avatar
if u want a faster time without money take it out and gut ur car it wont do much but it will do a lil
Old Apr 10, 2004 | 10:47 PM
B2FiNiTY's Avatar
Cons out weigh the pro.
_gurusan_
Oct 11, 2011 07:40 AM
Sliced Beard
Honda Motorcycles
27
May 2, 2008 09:01 PM
count_chocula
27
Jul 11, 2007 09:53 AM
brian g
Jun 3, 2004 01:19 PM
JDM_Risa
Nov 13, 2003 07:34 PM
