how do I remove the old head gasket?
Old Apr 10, 2004 | 05:23 PM
GSR4door1's Avatar
Default how do I remove the old head gasket?
are there any chemicals or something to take this stuff out?
http://www.geocities.com/proskong/
Modified by GSR4door1 at 5:36 PM 4/11/2004
Old Apr 10, 2004 | 05:24 PM
Kendall's Avatar
Red X???
Old Apr 10, 2004 | 05:26 PM
GSR4door1's Avatar
Default Re: (Kendall)
whats red x?
Old Apr 10, 2004 | 05:29 PM
Kendall's Avatar
Default Re: (GSR4door1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR4door1 &raquo;</TD></TR><TR><TD CLASS="quote">whats red x?</TD></TR></TABLE>
I was noting that initially, your picture didn't show up and a red X showed up instead. You can take a scraper and get it off, however be careful not to get any particles into the water jackets, or in the cylinders.
Old Apr 10, 2004 | 05:30 PM
shamoo's Avatar
Will you make something up for me please?
I used a razor blade.
Old Apr 10, 2004 | 05:59 PM
..::91TEG-G2::..'s Avatar
Default Re: how do I remove the old head gasket? (GSR4door1)
bump.. im not sure but u need a bump to get an answer.. hope u get one..
good luck
Old Apr 10, 2004 | 07:48 PM
deepgreengsr's Avatar
carb cleaner/ rag and razor blade.
Old Apr 10, 2004 | 10:32 PM
cougar10ag's Avatar
i forget who makes it... maybe permatex... they make a gasket remover.. my tech teacher got it. it worke pretty good for a cork gasket on an oil pan.. but we ended up using a wirewheel on it so it was perfect.. but that **** is like acid. bubbles up and eats at it
try getting a can of that, then use a scraper
Old Apr 10, 2004 | 10:46 PM
xplanetearth420x's Avatar
Default Re: (cougar10ag)
razor blade
Old Apr 10, 2004 | 10:49 PM
WhiteTegSE's Avatar
Default Re: (xplanetearth420x)
pull as much off as possible... I use gasket remover of some type and I also use a Die grinder with Roloc bristle disc's for alumium blocks too.. but thats takin it far tho...
Old Apr 11, 2004 | 07:46 AM
garados's Avatar
razor for sure. good luck
petarr
Apr 4, 2006 05:09 PM
megotvtec
Mar 10, 2004 01:22 PM
nd8ch
14
Feb 1, 2003 03:24 PM
Evs-One
Jul 23, 2002 04:43 PM
