problems...
waddup peep i got tranny problem .....from my brother civic coupe tranny is leakin and shiftin gear to gear is ok but hearin a clickin noise in tha tranny soo i dunno tha problem is
Modified by JdM_HoNda at 4:21 AM 4/17/2004
Wait a minute... Is he talking about the teeth on the axle splines??? Cause they are different. I spent an entire day finding out the answer to this one...
1988-1990 have 23 splines on the hub end of the axle. The 1991 and SI only have 26 teeth, just like an Acura Integra of the same year. Are you talking flywheels or axles here???
Just trying to help.
Scott
Scott
88 has 21 splines. Must use 88 clutch and fly as the diameter is 190mm.
89 has 20 splines. If you have an 89 flywheel you must use 89 clutch as the diameter is 200mm, or upgrade the fly to a 90-91 and use 90-91 clutch.
90-91 has 20 splines. Can mix and match 90-91 clutch parts and flywheels as the diameter is 212mm.
Gant
15
Feb 17, 2004 03:01 PM
KevronsEG
Jan 14, 2003 08:48 AM
