tach point 7th gen
I need to find a point to connect my shift light and MSD RPM window switch up to. Coil on plugs and I can't find a single point for the connection. I've been reading through my Honda Service Manual without luck, help!!!!
You mind being a little more clear on what you need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaAccordSiR »</TD></TR><TR><TD CLASS="quote">MSD RPM window switch</TD></TR></TABLE>
Does that make your window roll up faster?
Its a switch that activates at a certain rpm and then shuts down at another. Basically its for my NX kit, sprays nitrous when I hit this rpm, then stops spraying when I hit another rpm.
I'm pretty sure I need to use the speed reference feeding the computer, a blue/red wire on connector E, pin 25.
Tinker219
Sep 17, 2004 04:15 AM
