hit curb, bent suspension
guys, i drilled a curb, and took a good chunk out of my rim... hit it hard enough to shift the entire suspension back about 1/2". resulting in the car pulling very hard to the right. i replaced the LCA and that shifted it forward some, but not back to it's stock location. the UCA didn't appear to be affected, and i didn't replace the tie-rod end because when i compared the replacement one to the one on the car it wasn't bent at all.
any ideas what else it could be? i was suggested that it might be the spindle/even the strut. i don't think the strut would shift the wheel 1/2" back.
Sounds like me last summer
. I hit a curb doing about 60 and bent my rear tire under my car. 2 rims mashed. Had to replace the rear cross member, and all the trailing arms on that side. Old bolts kept snapping and cause me to redo both sides$$$ All OEM new replacements$$$...I figure I'd treat my baby we.ll.
I can't answer your question, but I thought i'd let you know that I can relate.
. I hit a curb doing about 60 and bent my rear tire under my car. 2 rims mashed. Had to replace the rear cross member, and all the trailing arms on that side. Old bolts kept snapping and cause me to redo both sides$$$ All OEM new replacements$$$...I figure I'd treat my baby we.ll. I can't answer your question, but I thought i'd let you know that I can relate.
LaFlamaBlanca
Suspension & Brakes
18
Jan 27, 2013 05:35 PM
alfaaay
Suspension & Brakes
Oct 10, 2006 04:59 PM
illusion
23
Apr 1, 2003 03:25 PM
bent, car, civic, cost, crv, curb, hit, honda, images, rims, s2000, suspension, suspension2, suspentonhit, tires
