H22'd Ek Civic questions about injector resistor box....
Old Apr 10, 2004 | 10:23 AM
Honda_Tengoku's Avatar
Default H22'd Ek Civic questions about injector resistor box....
i wanted to wire in the injector resistor box on the underside of my dash of my car. I want to use the wires off my OBD 2 to OBD 1 adapter for ease of use. I was wanting to make sure that there are no other points from the ECU to the injectors where something that is controlled could not be affected my limiting the resistance near the ECU. Obviously once the injector resistor box is added the voltage will be reisited down to 2 to 6 ohms from that point on to the injectors. Also i wanted to make sure I am reading the wiring diagram correctly. Aparantly I am going to cut the injector power wires from the ECU and splice the power side (ECU side) all together with the one black wire from the injector resistor box? Then run the 4 individual black wires to each individual injector wire. Am I reading this correctly? Just making sure.
Modified by Honda_Tengoku at 11:34 AM 4/10/2004
Modified by Honda_Tengoku at 11:35 AM 4/10/2004
cehcivic15
Engine Management and Tuning
Oct 21, 2009 08:14 PM
mickey b16
May 26, 2009 04:02 PM
markgo
Nov 8, 2006 11:39 AM
BlownBlackSi
Sep 30, 2006 01:28 PM
Honda_Tengoku
Apr 11, 2004 03:00 PM
