anyways.......anyhow?
Old Apr 9, 2004 | 11:46 PM
hondaACCORD's Avatar
Default anyways.......anyhow?
is it a good idea to make an automatic 1994 honda accord fast? does it shift as slow as people say? is it a good car to upgrade? i dont have much knowledge.
what is a good idea to make a 1994 honda accord as quick as possible.
-jonathan-
Old Apr 10, 2004 | 12:47 AM
Tadeh's Avatar
Default Re: anyways.......anyhow? (hondaACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaACCORD &raquo;</TD></TR><TR><TD CLASS="quote">is it a good idea to make an automatic 1994 honda accord fast? does it shift as slow as people say? is it a good car to upgrade? i dont have much knowledge.
-jonathan-</TD></TR></TABLE>
Alright here's what you do ... find a nice red brick, drive up to a canyon somewhere (with a nice cliff), pull the e-brake, place the brick on the pedal, get out or just hop into the passenger seat, pull the e-brake down and watch that puppy tear it up.
Old Apr 10, 2004 | 04:45 AM
TiggsCRX's Avatar
Sure why not. I've got a friend trying to make his auto 97 Grand Am Se fast, hahaha...Had to resort to nos cuz he's too scared to do engine work since it's his daily driver..
Anyway, you can make it fast, maybe not running 13's or 14's without some really heavy mods, but you can still make it fast. I don't know much about automatics and ECU's but maybe you can edit the ecu a little and change shift points etc to help out. They did make b16's for automatics ya know, so they musta thought the people who don't wanna drive stick still want a little power.
Old Apr 11, 2004 | 10:11 AM
meanEG's Avatar
Default Re: (TiggsCRX)
get a h22 full swap.problem solved i seen a h22 with exhaust, stock header witha 2.5 collector, intake skunk2 stage 1 cams put down 200 whp witha greddy emanage
Old Apr 12, 2004 | 06:05 AM
jagged4698's Avatar
Default Re: (meanEG)
Or you could just do the simple thing and swap it over to a manuual tranny... It will cost a pretty penny but if your looking for speed do that and an H22 swap and you will be set
Old Apr 12, 2004 | 11:48 AM
fw190bvi's Avatar
Default Re: (jagged4698)
how many miles on the engine???
turboing would be more cost effective than an h22 swap....but then reliablilty becomes an issue....
no matter WHAT, ur gonna wanna get a manual tranny....honda ATs cant take that much of a beating
TURBO F22/H22 - Accord 5spd (w/ an LSD would be realllll nice).....longer gears help u to keep @ high spool/boost
NA F22/NA H22 - H22/Prelude tranny w/ OEM LSD....gears are shorter, perfect match for a well built NA engine
i would shy away from boosting an h22....very high compression and aluminum internals ....ud need to do some work on it to make it even somewhat reliable
cptnooble
Mar 30, 2011 12:41 PM
kenman923
Sep 29, 2008 09:35 AM
KayOs
Apr 5, 2006 02:55 PM
