OiL light stays on in my 90 crx HF
Old Apr 9, 2004 | 08:34 PM
hondacrx90's Avatar
Default OiL light stays on in my 90 crx HF
I've put a b16a in my crx HF, Ever sense i got the car running and drivable, the oil list stays on, I've put 1300 miles on it and it has never locked up so it has oil pressure, I've changed the oil pressure switch out also, but the oil list stays on what else could it be?
Old Apr 9, 2004 | 08:51 PM
onePOINTsix's Avatar
Default Re: OiL light stays on in my 90 crx HF (hondacrx90)
have you added oil!?! DUH! The oild light comes on to tell people like you to add more oil or that something is very wrong. It's not the sender... ADD SOME DAMN OIL!
PS. Your oil pump could be bad too
Old Apr 9, 2004 | 08:52 PM
hondacrx90's Avatar
Default Re: OiL light stays on in my 90 crx HF (Sideout)
Don't you think after 1300 miles it would of locked up if it needed oil you fucken idiot, i'm not that stupid.
Old Apr 9, 2004 | 08:54 PM
ok read the bottem of my post, it's not the sender for sure, something is very wrong with your engine, dont drive it untill you locatre the problem
Old Apr 9, 2004 | 08:56 PM
hondacrx90's Avatar
Yea i have parked it, How do i test to see if its the Oil Pump or not?
Old Apr 9, 2004 | 11:07 PM
RCautoworks's Avatar
There is no way to check the oil pump, its mechanical. I would look into 2 things, a new oil pump and new bearings for the engine. If the clearance is to high your oil pressure will be low.
Old Apr 9, 2004 | 11:51 PM
garlic jr's Avatar
Default Re: OiL light stays on in my 90 crx HF (90blackcrx)
make sure the black plug under the dizzy on the left of the valve cover is plugged in properly, its the oil pressure sensor and if its bad it will throw that light.
just a thought.
Old Apr 10, 2004 | 11:28 AM
hondacrx90's Avatar
Default Re: OiL light stays on in my 90 crx HF (garlic jr)
what is a dizzy? and i replaced what i thought was the oil pressure switch, located on the back side on the left side of the oil filter one wire sensor.. is that what you talking about? or is that a different sensor.
Old Apr 10, 2004 | 11:46 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">make sure the black plug under the dizzy on the left of the valve cover is plugged in properly, its the oil pressure sensor and if its bad it will throw that light.
just a thought.</TD></TR></TABLE>
the oil switch is a NC switch (meaning normally closed).. your oil light is actually always on - oil pressure is what turns it off, so if the sensor was switch out twice then there is something wrong with the circuit (probably not) or the oil pressure is !LOW!
Your 'drive it and see if it locks up' test is not very bright
Old Apr 10, 2004 | 12:43 PM
What plug are you talking about ? The only plug over there that has to do with oil pressure is the vtec plug and that is not under the distributor and it would through the check engine light but it would not through the oil low light.
Old Apr 10, 2004 | 01:49 PM
legacytunes's Avatar
i would get an oil presure gauge on it rite awy to see what kind of pressure you have that will tell you a whole lot. instead of swaping parts in and out. if you have good oil pressure check your wire s for -&gt; -&gt; thats a start!!
Old Apr 10, 2004 | 04:36 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: OiL light stays on in my 90 crx HF (legacytunes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legacytunes &raquo;</TD></TR><TR><TD CLASS="quote">i would get an oil presure gauge on it rite awy to see what kind of pressure you have that will tell you a whole lot. instead of swaping parts in and out. if you have good oil pressure check your wire s for -&gt; -&gt; thats a start!!</TD></TR></TABLE>
Yeah, a mechanical autometer oil pressure gauge. you NEED one first.
Old Apr 10, 2004 | 05:52 PM
EG8R's Avatar
Default Re: OiL light stays on in my 90 crx HF (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
the oil switch is a NC switch (meaning normally closed).. your oil light is actually always on - oil pressure is what turns it off, so if the sensor was switch out twice then there is something wrong with the circuit (probably not) or the oil pressure is !LOW!</TD></TR></TABLE>
Hey man. Don't confuse them anymore than they already are! lol
Old Apr 10, 2004 | 09:47 PM
2point2's Avatar
Default Re: OiL light stays on in my 90 crx HF (skelly ed6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 &raquo;</TD></TR><TR><TD CLASS="quote">Hey man. Don't confuse them anymore than they already are! lol</TD></TR></TABLE>
haha.. my job is all about sensors and switches so i might get a little carried away sometimes.. but that is very basic switch knowledge...
Old Apr 11, 2004 | 02:10 PM
hondacrx90's Avatar
I forgot to say, there is a hair line crack, in between the head, and head gasket. It don't start bubblin oil through it til the oil gets hot and thin, but its constantly lossing oil pressure, i didn't think it was that much oil pressure and oil to have the light on 24/7. The leak is located right under the vtec where the seal is between the head and head gasket at that corner of the head.
Old Apr 11, 2004 | 06:50 PM
Banned
Uh, you're talking about the VTEC solenoid housing? Take a pic.
Yuta
13
Nov 11, 2016 05:32 AM
itzyaboyzeem03
Jul 1, 2016 04:40 PM
Integritycaptain90
Dec 22, 2007 07:26 PM
coronadrinker
Nov 18, 2006 04:05 PM
integra_94
Aug 31, 2004 09:10 PM
