A question for 2point6 about manual tensioner
Old Apr 9, 2004 | 08:00 PM
Variable J's Avatar
Default A question for 2point6 about manual tensioner
I just did the manual conversion today. On your write up you list 9 items. I only used five. The three bolts the washer the spring and the pulley. What are the other items you listed. Looks to me like balancing belt pieces. I'm a bit confused why you put those in there. Im simply using the old h22 balancer belt peices. Perhaps you could clear up my confusion. And oh boy is it hard to get the belt on. I tried for an hour with no luck. I guess I will just try and sit it on the end of the cam gears and give it hell. Only problem is the right cam gear always wants to move. Anyway and insight would really help.
Old Apr 9, 2004 | 08:06 PM
Shakes's Avatar
space cadet
Default Re: A question for 2point6 about manual tensioner (Variable J)
i dont think that he visits here too much. it would most likely benifet you to email him or hit up his site http://www.collectiveracing.net
but please post results here for our benifet as well!
Old Apr 9, 2004 | 08:11 PM
4bidden's Avatar
Default Re: A question for 2point6 about manual tensioner (shakes)
Off the top of my head I KNOW you need the following if you reuse the H22 balancer belt stuff
manual tensioner
black "nipple" for the tensioner spring
tensioner bolt that goes into the block
washer
i "think" another nipple that the tensioner pivots on
That might be it, 5 things
Old Apr 9, 2004 | 08:23 PM
Variable J's Avatar
yeah thats what I got. Thanks
the boogler
Mar 25, 2012 06:18 AM
accordmatt
Feb 24, 2011 10:15 AM
Ziggymidget5
May 22, 2005 03:38 PM
machine4321
Mar 15, 2005 08:43 AM
graphic
Nov 1, 2004 10:23 PM
