NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ!
Old Apr 9, 2004 | 07:02 PM
BlackEG6's Avatar
Default NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ!
Got a spray gun but dunt know how to use it. plz help
Old Apr 9, 2004 | 07:08 PM
Gurdjieff's Avatar
Default Re: NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ! (BlackEG6)
Mr. Google is your friend.
Old Apr 9, 2004 | 07:20 PM
EK MONEY's Avatar
Default Re: NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ! (Gurdjieff)
mix, spray and clean soon after!
Old Apr 9, 2004 | 07:39 PM
TRD MA70's Avatar
Default Re: NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ! (peagreenhatch)
to use it you putthe paint in the white canister using a paint filter. When you spray it you want the air and paint coming out to be even so to adjust the air you use the **** thats on the backside of the handle. The part facing you when you'r painting. It really isnt that hard to use. Just put a roll of paper on a garage wall of something and practice. Of couse you'll need an air compressor and hose. To clean it when you're done, take off the nossle, take off the canister that holds the paint, and also take off the air adjustment. Be carefule with that thought, the **** is connected to a pin that goes to the nossle of the gun and around that pin is a spring (just like a pen that has the clicking thing you know, when you take it apart theres that spring around the ink tube) then clean it by putting it in a paint gun cleaner or using brush. Cant think of it right now but theres a type of brush you can use and a type you cant (refering to the bristles). but if you use the wrong one your gun is f'd, so make sure you find out the answer before you try. When you think you're done cleanin hold the nossle tip up to a light and make sure you see light through all of the holes. Thats all i can think of right now. I may have described it poorly but hopefully you understand. Im sure someone else will have more to say/ clearly describe.
Old Apr 9, 2004 | 07:47 PM
Skeeter7424's Avatar
Default Re: NEED HELP ON HOW TO USE A SPRAY PAINT GUN PLZ! (TRD MA70)
if you need to ask how to use a paint gun, i wouldnt paint anything. take a good class on it before you try to do it. i know of a bunch of community colleges that do courses on painting like that. this isnt me flaming you, id just rather see sumthin get done right, and maybe if you get it down, you can make a little money doin it.
just my .02
...Skeeter
Loccster's Avatar
sounds like you have never used a spray gun before. Do u have an 3hp+ air compressor to back it up?
Old Apr 9, 2004 | 08:08 PM
BlackEG6's Avatar
thankz for the feed backz so far, yeah im kinda newB at using the gun, and i do have a compresor and all, .........was jus kinda curious boutz how to use the gun thatz all, im mayb jus gonna paint a bumper or so to play around/practice................ and thankz again
EG-SIXV-TEC
Paint and Body
11
Jan 22, 2012 03:48 AM
dem0nk1d
Paint and Body
Apr 15, 2011 03:21 PM
98tegLSvtec
Paint and Body
22
Mar 17, 2011 07:23 PM
Tyree
Dec 23, 2004 10:59 AM
johnzm
Feb 24, 2003 08:37 AM
