Integra Hondata on Dyno today, Problem!!!!! Plz help
Old Apr 9, 2004 | 06:24 PM
JR Integra's Avatar
Default Integra Hondata on Dyno today, Problem!!!!! Plz help
Just put the car on dyno today with the new hondata, car is a 95 integra Ls/vtec, jackson supercharged and when running on the dyno the ecu is not seeing boost?!?!?! Is there something in the wiring that could be causing this??
Thank you
Old Apr 9, 2004 | 06:34 PM
grndcont's Avatar
did you at one time install a check valve? also check to see wich map sensor the hondata thinks you are useing.
Old Apr 12, 2004 | 09:58 AM
JR Integra's Avatar
Default Re: (grndcont)
never had a check valve.........shop called today and said they needed the jackson map controller. Anyone else with hondata jackson charger have this problem??
Old Apr 12, 2004 | 11:59 AM
Spunkster's Avatar
Default Re: (JR Integra)
The map sensor on the throttle bodie will not see boost since it is before the blower. You need the map relocator from Jackson Racing.
Old Apr 12, 2004 | 01:51 PM
JR Integra's Avatar
Default Re: (Spunkster)
haha thank you spunkster, just needed a double verification.
siis2fast
Jul 1, 2003 09:54 PM
crx1856
May 14, 2003 10:14 PM
Snafu-Si
Mar 10, 2003 01:05 PM
JeremyL
Feb 20, 2003 10:12 AM
