yes, another "what should this car run" thread. ...but with REAL info:
Old Apr 9, 2004 | 02:43 PM
kaj's Avatar
kaj
Default yes, another "what should this car run" thread. ...but with REAL info:
this is an actual car. not "what if i build this".. let me know what ya'll think:
DC2:
2880lbs with driver
353whp/298fpt on N2O
assuming LS tranny with no LSD.
the guy will be test/tuning this month and i want so get some ideas of what he can run. his tuner tells him with a PERFECT run he could get a 11.6 @ 119 out of it, but he's looking for a low 12 (which should be no problem).
11.6 sounds possible with the power... not sure about the weight though.
any guesses?
Old Apr 10, 2004 | 10:57 AM
xJ.SLOTHx's Avatar
Default Re: yes, another "what should this car run" thread. ...but with REAL info: (kaj)
you forgot:
elevation of track
suspension setup
slick size and/or skinnies
Old Apr 10, 2004 | 04:35 PM
kaj's Avatar
kaj
Default Re: yes, another "what should this car run" thread. ...but with REAL info: (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">you forgot:
elevation of track
suspension setup
we'll just say elevation of: 635' (pretty much sea level)
suspension = coil-overs. that's 'bout it
24" slicks or will be running 225/15 BFGs.
Old Apr 10, 2004 | 04:54 PM
goforbroke's Avatar
MEAT PATTY
You have all the power on your side but that weight is pretty damn heavy close to 3000lbs, is probably going to hurt you alot.
Old Apr 11, 2004 | 05:51 PM
kaj's Avatar
kaj
Default Re: yes, another "what should this car run" thread. ...but with REAL info: (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">You have all the power on your side but that weight is pretty damn heavy close to 3000lbs, is probably going to hurt you alot.</TD></TR></TABLE>
:werd:
i just want to know how close to the "if all things go right" time his tuner quoted.
Old Apr 11, 2004 | 06:01 PM
91civicDXdude's Avatar
race it and find out
Old Apr 12, 2004 | 06:21 AM
1point5CRX's Avatar
Default Re: (91civicDXdude)
im throwing my guess out there: 12.5@115
Old Apr 12, 2004 | 02:21 PM
kaj's Avatar
kaj
Default Re: (1point5CRX)
thanks for an actual answer, bro!!
this guys is sort of a "nemisis". his car was tuned by a guy that doesn't like me or my group of friends too much (long story). anyway, i'm trying to get an IDEA of what he should run or what others here run with the same power/weight, etc. the guy is actually pretty cool, so we'll be pulling for him. i just want an idea of what is typical for his setup.
i know he won't run 11.6, 'cause NONE of us ever have a PERFECT run. i'm just looking for a ball park figure.
i'm thinking 12.4-12.6ish..?
Modified by kaj at 5:44 PM 4/12/2004
Old Apr 12, 2004 | 02:25 PM
HYBRID_H@TCH's Avatar
Default Re: (kaj)
running as much juice as he is..I say he will blow it up before it ever sees the track.(stock sleeved B20 block)
Old Apr 12, 2004 | 03:37 PM
Honda Sport's Avatar
I say a around low 12s@115-119mph.
OT: Kaj, is that your first name? hahaha...that's the first part of my lil bro's name.
Old Apr 12, 2004 | 04:44 PM
kaj's Avatar
kaj
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">running as much juice as he is..I say he will blow it up before it ever sees the track.(stock sleeved B20 block)</TD></TR></TABLE>
are B20 sleeves not as good as other B-series sleeves? he IS squeezing A LOT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">I say a around low 12s@115-119mph.
OT: Kaj, is that your first name? hahaha...that's the first part of my lil bro's name.</TD></TR></TABLE>
i'm figuring the same time. "kaj" is an old nickname from back in the day (back when i started getting on the 'net). i still use it 'cause i have email addresses with the name, etc
Old Apr 12, 2004 | 04:58 PM
1700anddroping's Avatar
Default Re: (kaj)
the b20 is a simese sleeve they are for nortorious for cracking at high hp levels.how much is he"how big of a shot is your friend running".
i have sprayed a 175 shot wet on a ls vtec w/oem parts .the car is a tract car.but if you get the mixture right anything is possbile .by the way that set up ran 7.03 @103 mph w/ 1.5 60 ft' .26x10x15 launching @ 5k anything above that and she breaks axles.
the only way to see what the car will run,is to take it to the tract .my guess is high 12's but who knows.but good luck with the set up.
Old Apr 14, 2004 | 02:59 PM
kaj's Avatar
kaj
Default Re: (1700anddroping)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">the b20 is a simese sleeve they are for nortorious for cracking at high hp levels.how much is he"how big of a shot is your friend running".
the only way to see what the car will run,is to take it to the tract .my guess is high 12's but who knows.but good luck with the set up. </TD></TR></TABLE>
you ran 7.03@103? wow hahaha.
this guy is squeezing more than 200. just look at his dyno numbers! his car has held up so far.
i know to wait and see how it does at the track, but i'm trying to get opinions of what everyone here thinks it will do BEFORE he goes.
Old Apr 15, 2004 | 12:26 AM
Default Re: (kaj)
well race him and find out..lol..if he beats you I will race him.
Old Apr 15, 2004 | 04:48 PM
kaj's Avatar
kaj
Default Re: (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">well race him and find out..lol..if he beats you I will race him.</TD></TR></TABLE>
robert already beat him pretty bad. and i beat robert
Topdawgg
Jul 14, 2007 09:40 AM
ebp_dc2
Apr 12, 2005 04:59 PM
allmota1.8
Jun 13, 2004 01:45 PM
mister2racer
May 14, 2004 04:16 PM
Jared
Nov 19, 2001 07:23 PM
