9005 Conversion
Yes it has been covered many times, although I wanted to make sure.
A simple yes or no answer will be fine.
1. Start off with 9005 Socket w/ 9005 Bulb
2. Remove two plastic guides off inside the socket.
3. Remove 3mm of plastic off the exterior of socket.
Correct?
Now do I need to put the rubber o-ring off my 9006 socket onto my 9005 bulb? And now this 9005 socket plug straight into my stock harness, correct?
Correct?
sounds like you got it.
here's a link that was useful when i did it.
http://www.bmwe34.net/E34main/...t.htm
