Another Valve Adjustment Problem!!!(Question)
Old Oct 26, 2001 | 11:10 PM
tjtruong's Avatar
New User
Default Another Valve Adjustment Problem!!!(Question)
I adjusted the valves but now the engine seems to be alittle louder and so does the ticking. How is it suppose to sound after the adjustment? Alot quieter or just minimal noticablity? If its not suppose to be loud what do you think I could have done wrong? NOTE:: This is my first time doing the VAlve Adjustment.. I'm using the helms and the C-speed website http://www.c-speedracing.com/howto/v...lveadjust.html as a guide. Any help will be appreicated...
Ps. I want to finish it tonight because I want to go to the cruise tomorrow in southern California.. PlEASE HelP!!! THANKS
thomas
Old Oct 27, 2001 | 12:44 AM
Toda Party's Avatar
Default Re: Another Valve Adjustment Problem!!!(Question) (tjtruong)
I was under the impression it was supposed to sound quieter...are u sure u did everything according to spec? not doubting u or anything but:
intake valves: 0.006 - 0.007 in (0.15-0.19 mm)
exhaust: 0.007 - 0.008 in (0.17-0.21mm)
if u did it within specs and used the feeler guages correctly and tightened the screws and nuts corretly... i remember one of the trickier things was making sure the locknut was tight and didnt move while we were adjusting the screw...so maybe you might have loosened the locknut inadvertently and that might be the problem...-shrug-
[Modified by Toda Party, 9:49 AM 10/27/2001]
Old Oct 27, 2001 | 05:32 AM
GRM Scott's Avatar
25 Year Member
Default Re: Another Valve Adjustment Problem!!!(Question) (Toda Party)
Did you do it with the engine absolutely cold? The Type R engine isn't quiet, per se...it does make some noise. You might be paying too much attention to it If you're worried, get in there again and check everything. Did you torque the locking nuts to spec?
Old Oct 27, 2001 | 09:52 AM
tjtruong's Avatar
New User
Default Re: Another Valve Adjustment Problem!!!(Question) (Aleph)
Thanks I"ll try it again.
Old Oct 27, 2001 | 10:51 AM
mattymatt's Avatar
New User
Word of caution... don't over tighten the lock nuts! You can strip the thread pretty easily... either that, or I must be super human.
Old Oct 27, 2001 | 01:44 PM
tjtruong's Avatar
New User
Default Re: Another Valve Adjustment Problem!!!(Question) (mattymatt)
Yea.......!! i did it....... the engine sounds normal again.. nice and relaxed at idle... THanks For all the Help gUYS.. I love this board......
thomas
Old Oct 27, 2001 | 02:01 PM
PROFILES2000's Avatar
well it sounds like we have a pro here
Old Oct 27, 2001 | 10:29 PM
Toda Party's Avatar
Default Re: Another Valve Adjustment Problem!!!(Question) (PROFILE GSR)
u damn right
Jax4gencivic
Jan 17, 2023 06:41 PM
AlfieRoach
Oct 16, 2010 06:51 PM
STATek9
Sep 18, 2009 08:47 AM
t3hatch
Oct 15, 2005 04:49 PM
mattymatt
Aug 4, 2001 04:39 PM
