Falken Azenis Psi
we have used them for drag and found them to be one of the best radials aside from like a BFG street legal drag. we normaly set them to 18-20psi should work well.
we have run more then one mid 12sec pass with azenis on a all motor hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGWANNAB2NR »</TD></TR><TR><TD CLASS="quote">we have used them for drag and found them to be one of the best radials aside from like a BFG street legal drag. we normaly set them to 18-20psi should work well.
we have run more then one mid 12sec pass with azenis on a all motor hatch. </TD></TR></TABLE>
really, ive tried the same thing at about 18psi and the workk like **** lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen »</TD></TR><TR><TD CLASS="quote">on my friends ITR he runs 12 psi ...he was hittin 14.4s all day with 2.2 60fts ...but he was having sick wheel hop
I think 12 psi is too low but to each his own. I would also recommend anywhere from 18-20 psi, you should be able to pull off 2.1x 60' times.
</TD></TR></TABLE>I think 12 psi is too low but to each his own. I would also recommend anywhere from 18-20 psi, you should be able to pull off 2.1x 60' times.
I have a JDM Type R in my hatch (180hp/127tq). I run my Azenis at 20psi, heat them up with a 2nd gear burnout in the water.
60' 2.074
1/4 13.567
mph 102.5
I think Azenis are great tires for drag. Not the best, but deffinetly good!
60' 2.074
1/4 13.567
mph 102.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy »</TD></TR><TR><TD CLASS="quote">i really dont think it matters cause it is a road race tire. so the side walls arent going to give. </TD></TR></TABLE>
BFG's are definately the best but for the price I havent used a better drag radial than Azenis. When I switched to 555r's(didnt go with BFG's because these are my street tires) my 60ft were actually the same as the azenis. The 555's were actually not as consistent as the azenis. I would do 2.1's all day long on the azenis and the 555's were 2.1-2.3.
555r's
555r's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A »</TD></TR><TR><TD CLASS="quote">
I think 12 psi is too low but to each his own. I would also recommend anywhere from 18-20 psi, you should be able to pull off 2.1x 60' times.</TD></TR></TABLE>he tried 18-20 and wasnt having good luck so thats when he went down to 12psi ...still wasnt that good but better than before ...i think next time ill talk him into trin 18-20 again and tring a 2nd gear burnout in the wetbox
streetrage
Jan 9, 2004 08:18 PM
