throttle body without manifold
Old Apr 9, 2004 | 12:10 PM
JforJonathan's Avatar
Default throttle body without manifold
would putting on a bigger throttle body help gain in performance if I dont get a better flowing intake manifold? In other words....do i need a performance intake manifold (skunk 2) if I get a bigger throttle body?
Old Apr 9, 2004 | 03:59 PM
SPD DMN's Avatar
Default Re: throttle body without manifold (Dj Villain)
bump
Old Apr 9, 2004 | 04:19 PM
MikeNice's Avatar
It would help but not as much as getting a bigger intake manifold like Skunk2. Its getting high air flow thru the big throttle body and then less air flow in your stock intake manifold.
Its like having just an exhaust canister on some stock piping in your car. Probably wouldn't dyno anything.
Old Apr 9, 2004 | 04:48 PM
barto's Avatar
Default Re: throttle body without manifold (MikeNice)
just upgrading the tb wont really do anything because if you think about it what good is a bigger tb if its just gonna be bottle-necked anywase. if you get a bigger one you could always get an aftermarket manifold like skunk 2 or edelbrock. your other option is to port match your current manifold. if you do that then i think you will notice a difference and also better throttle response
Old Apr 9, 2004 | 04:50 PM
turboman's Avatar
Need to match the manifold to the throttle body. Not hard I'll be doing this soon myself. I ordered and extra manifold off ebay and a 68mm throttle body.
I run a turbo system but with a NA engine you may need to tune your motor to take advantage of the new manifold and throttle body. Luckly my car is starving for fuel and air so anything I do will improve it.
Old Apr 9, 2004 | 04:56 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: throttle body without manifold (turboman)
I actually took my stock tb and machined a larger inner diameter in it. I didn't port match my IM to match yet but as far as power, nothing noticable. I did completely polish the inside of the TB and have noticed better throttle response. I am guessing this is cause by lest "drag" in the throttle body. Be careful not to machine where the throttle plate is unless you have a larger diameter plate. I would suggest leaving the throttle plate in and using a dremel bit with a taper on the end to round the final progression to the stock diameter by the throttle plate and then do the same on the other side of the plate. I mean you do still have a little "hump" in the throttle body that will cause resistance but the expanded opening should flow better or at least slightly better. Happy Tuning!
Old Apr 9, 2004 | 04:58 PM
krzyaccord's Avatar
Default Re: throttle body without manifold (HondaFanatic708)
I think you should get a mani to match with your tb
Old Apr 9, 2004 | 05:39 PM
JeremyL's Avatar
Default Re: throttle body without manifold (krzyaccord)
just get ITB's then you dont even have to worry about a manifold at all :-)
Old Apr 9, 2004 | 11:48 PM
thanks for all the replies i think i will get both the IM and throttle body.
Old Apr 10, 2004 | 12:54 AM
barto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">
I run a turbo system but with a NA engine you may need to tune your motor to take advantage of the new manifold and throttle body. Luckly my car is starving for fuel and air so anything I do will improve it. </TD></TR></TABLE>
how is high compression and boost workin for you?
Old Apr 10, 2004 | 12:15 PM
turboman's Avatar
Default Re: throttle body without manifold (barto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barto &raquo;</TD></TR><TR><TD CLASS="quote">
how is high compression and boost workin for you? </TD></TR></TABLE>
I have a fully built SOHC motor. Unfortunately I got bored and never finished what I started. So I still have the stock TB, manifold, injectors, and 2.5inch downpipe and exhaust. I really need to change those parts before I can safely see 300hp.
blackoutvtec845
May 11, 2010 05:49 PM
shahriar35
Jan 31, 2010 12:13 AM
done
Sep 30, 2003 08:47 PM
