any hope for my engine bay?
Old Apr 9, 2004 | 10:33 AM
hott-nix's Avatar
Default any hope for my engine bay?
i took it to a detailer whos specialty is engine bays and he told me i was better off replacing alot of the parts if i wanted them to look thier best.
the valve cover and spark plug cover are being replaced anyway, but is there anything out there that can make this thing look new again? i doubt a regular wash is going to do the trick.
a larger/higher res shot can be viewed here
http://www3.sympatico.ca/albert_n/DSC00049.JPG
Old Apr 9, 2004 | 10:35 AM
Erik95LS's Avatar
Default Re: any hope for my engine bay? (hott-nix)
doesn't look to me like anything a little simple green and elbow grease couldn't fix. You could probably paint that rusty PS bracket and then it would probably look almost new. What happened to it that it all looks like that?
Old Apr 9, 2004 | 10:39 AM
spnbb2
Guest
Posts: n/a
BEATER!
Old Apr 9, 2004 | 10:45 AM
TRD MA70's Avatar
Default Re: (Ludinitup)
i work at a detailing shop where we do engines a lot and mine wasnt as bad as yours but my black plastic peices and other parts still didnt shine like i wanted them too, i highly, HIGHLY doubt yours will too. It will take quite a bit of work. Spraying a little interior dressing in the bay after you spray it down and let it mostly dry will help it look cleaner too
Old Apr 9, 2004 | 10:47 AM
rocco's Avatar
WTF,unless its overspray I dont see a big problem here
Old Apr 9, 2004 | 10:52 AM
redlinetuning's Avatar
Default Re: any hope for my engine bay? (rocco)
mine was worse than yours after i got it back from the shop.. it's not overspray though.. just really dusty. but i only have a d motor in.. and i'm not gonna clean it until the c5 motor is ordered and the d is out. simple green should do the job.
Old Apr 9, 2004 | 11:01 AM
hott-nix's Avatar
Default Re: any hope for my engine bay? (redlinetuning)
the previous owner didn't take care of it. i opted not to do any work on it while there was still snow on the ground (got it in january)
a lot of the metal is either oxidized or rusting and the rest just looks like crap. for example, the ground wire running from the valve cover to the chassis need to be replaced.
some of the wiring and a hose or two look like they should be replaced as well(but they could just very well be dirty)
there is some dust/salt over the entire thing (canadian winters are a bitch)
Old Apr 9, 2004 | 11:07 AM
TRE_'s Avatar
i think there is hope for it... but it'll definantly take some time and patience. i've always liked using that CD-2 engine detailing kit -- comes with two cans, one degreaser, and the other is a dressing type of stuff. some simple green would help too.... along with some flat black paint.
Old Apr 9, 2004 | 11:14 AM
uNF$@#!'s Avatar
Default Re: any hope for my engine bay? (THE_HX)
simple green.
Old Apr 9, 2004 | 11:17 AM
PSU's Avatar
PSU
formerly DxHatchback
simple green with make that look new
when i got my car the engine was worse than that, now it looks new
Old Apr 9, 2004 | 11:59 AM
Works Euge's Avatar
Default Re: any hope for my engine bay? (DxHatchback)
not a big problem here at all...enging degreaser at kragen for like 2 dollars a can...get 2 of em and spray the **** out of ur engine, then rinse it lightly with water and ur **** will be shining...good luck mann...peace
Old Apr 9, 2004 | 06:35 PM
TRD MA70's Avatar
Default Re: any hope for my engine bay? (pinoy16typer)
all simple green is, is <U>basically</U> degreaser. Just go buy a big container of degreaser. If you have a pressure washer, thats good but if not, go to one of those local car washes where you pay like 25 cents for 5 minutes and spray the engine down, pressure wash it and do it over and over. You can leave the dist. cab exposed if you spray around it and start your car with the hood open (so the steam rises rather then seeping into it) or just cover it with a plastic bag. i do bays like yours almost everyday. The valve cover is SOL though.
Old Apr 9, 2004 | 06:47 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocco &raquo;</TD></TR><TR><TD CLASS="quote">WTF,unless its overspray I dont see a big problem here </TD></TR></TABLE>
I agree. Just some Engine Brite and elbow grease, along with a little paint for the discolored or rusted brackets, and after that, some rubber/plastic dressing, and you're golden kid . If you were in SD, I'd help you do it, it's easy.
Old Apr 9, 2004 | 07:11 PM
ceasar of mgineering's Avatar
▓spam and rice▓
Default Re: any hope for my engine bay? (rodrez)
castrol Super Clean!!!
Old Apr 9, 2004 | 07:17 PM
FF-sean's Avatar
Default Re: any hope for my engine bay? (ceasar of mgineering)
i say sell you engine and clean it
Old Apr 9, 2004 | 07:40 PM
EJ1_519
Guest
Posts: n/a
Default Re: any hope for my engine bay? (ReaL JDM Eg6)
make the trip down to london Ontario, and I can help you clean your engine bay.
I've done it to all my friends and my car also
I'll post a pic tomorrow of how it looks after winter without washing it
Old Apr 9, 2004 | 08:47 PM
DC4KiD's Avatar
Steam clean is your friend.
Old Apr 10, 2004 | 12:13 AM
ill45's Avatar
Default Re: any hope for my engine bay? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">doesn't look to me like anything a little simple green and elbow grease couldn't fix. </TD></TR></TABLE>
Old Apr 14, 2004 | 01:09 PM
hott-nix's Avatar
Default Re: any hope for my engine bay? (EJ1_519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_519 &raquo;</TD></TR><TR><TD CLASS="quote">make the trip down to london Ontario, and I can help you clean your engine bay.
I'll post a pic tomorrow of how it looks after winter without washing it </TD></TR></TABLE>
if only that werent a 5 hour drive
i got myself a jdm CTR valve cover to replace the curent... so thats no problem
just getting the rest of the crap looking somewhat clean is my only problem.
i've never really done it myself.. i've pretty much only had other people to it for me
Old Apr 14, 2004 | 01:21 PM
debogsr's Avatar
hey if u are going to replace the spark plug cover, would you like to sell it to me?
Old Apr 14, 2004 | 02:42 PM
hott-nix's Avatar
Default Re: any hope for my engine bay? (debogsr)
not selling it yet
but i'll post it in the FS section when the time comes
Old Apr 14, 2004 | 02:49 PM
NickQ's Avatar
https://honda-tech.com/zerothread?id=715484
Old Apr 14, 2004 | 11:25 PM
debogsr's Avatar
if you do sell it, please email me before hand. I have been looking for one for a while and cant seem to find one. Thanks man id appreciate it, good luck cleanin your bay up. kdeberna@calpoly.edu
Old Apr 15, 2004 | 08:51 AM
Thayne's Avatar
New User
Default Re: any hope for my engine bay? (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">simple green.</TD></TR></TABLE>
Old Apr 15, 2004 | 09:03 AM
B Speed's Avatar
Default Re: any hope for my engine bay? (Thayne)
Simple green is def the way to go...
