Tires how to determine number?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxStreetRacer »</TD></TR><TR><TD CLASS="quote">Hey whats up i have slicks and dont need to worry yet but what are these how are they measured?
205/45ZR17 88W 205/50ZR17 93W
What are the numbers how are they measured?
205 is the width of the tires.
45 is the thickness of the tires.
ZR is the tires speed rate or something like that. (someone correct me)
17 is the size of the rim the tires will fit.
88W/93W, i have no clue.
you need to find out what the offset is. maybe tirerack.com can help you.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires »</TD></TR><TR><TD CLASS="quote">
you need to find out what the offset is. maybe tirerack.com can help you. </TD></TR></TABLE>
Thanks but what do the numbers <U>measure</U> in inchs?,milimeters???
Modified by CrxStreetRacer at 8:03 PM 4/9/2004
width is in milimeters. (205 mm)
height, tallness is a percent of the width (45% of 205)
17 is in inches (duh)
here's another site to explain http://www.tirerack.com/tires/...e.jsp
Xymox007
Aug 24, 2004 01:31 PM
