HOW to tell the difference between obd-1 and obd-2 dash harness
i recently bought a gsr dash, i "supposly" have a 2000 dash so i know it would be obd-2 if that was right, but is there anything on the harness that identifies OBD-1 OR 2? i am doing a dash swap and i need a obd1 but i cant tell. please help me out guys.
i put a gsr dash in my civic..all you have to wire up is the cluster...hmm...rewire the clock...defrost button won't work..and rewire the hazard button..i believe that's about it...need more help...pm me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic »</TD></TR><TR><TD CLASS="quote">i put a gsr dash in my civic..all you have to wire up is the cluster...hmm...rewire the clock...defrost button won't work..and rewire the hazard button..i believe that's about it...need more help...pm me.</TD></TR></TABLE>
thats cool but theres an easier way to do it... use the integra dash harness.. thats what this guy is tryin to do and hes on the right path....
do you have access to a helms manual or any shop program?? check the layout for the fusebox on both years... im not sure what the differences are between the 2 harnesses... ill try to look it up in the helms if you cant find anything..
hope this helps.. good luck and if you need any help with the repinning i've done it already so just pm me.. i had a obd1 harness out of a 96 and all i had to do was repin the gray plug because the integra one has just one extra column (2 pins) and it wouldnt fit in the civic fusebox.. other than that the wire colors and locations are the same...
EDIT: this might be easier.. just go to ur car and see if u can plug the green and blue plugs in.. the harness should have 3 main plugs that go to the fusebox..
