93 civic hatchback... pity me.. i have questions.
Old Apr 9, 2004 | 08:14 AM
civicHB0413's Avatar
Default 93 civic hatchback... pity me.. i have questions.
i have a ::shudders:: civic hatchback CX with an 8 valve 1.5L and i was wondering if i got a DX 16 valve top end, would it bolt up to my CX bottom end? would this and a DX or SI transmission give me more power? turbo charging would be my next step, would having a DX engine just make it hard to turbo? i'm unexperienced with engines and need some answers. thanks!
Old Apr 9, 2004 | 08:22 AM
Vero's Avatar
To do all that it sounds like you'd be spending close to the cose of a z6 motor (especially if you had a shop do it)
Otherwise, im not 100% sure, but I think the CX cam isnt design for 16 valve. Meaning there is only space for 2 valves on the cams.
There was a thread not to long ago where someone posted CX cams and only 2 had space for 4 valves only 2.
Someone verify this for him and me, I dont know CX's all to well.
Old Apr 9, 2004 | 08:42 AM
92BlackSi's Avatar
Ah there is also no valve relief on the pistons for the extra 2 valves. Swap the CX out, otherwise live with it IMO.
Old Apr 9, 2004 | 11:35 AM
93hondaboy's Avatar
Default Re: (92BlackSi)
i got a black d16z6 power ex coupe and i ran a damn 17.3 , i wana kno what can i do to improve my launch. or what rpm should i launch at to run 16's:h:
Old Apr 9, 2004 | 11:52 AM
stew18564's Avatar
your problem there is also no valve relief on the pistons for the extra 2 valves on a cx motor..so what you need to do is get a d16z8 swap for your car, then build that up alittle bit and turbo
Old Apr 9, 2004 | 12:06 PM
mafioso102's Avatar
New User
Default Re: (stew18564)
Once again people...dont speak unless you know!!! I can believe the amount of wrong information people try to pass off as knowledge!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stew18564 &raquo;</TD></TR><TR><TD CLASS="quote">your problem there is also no valve relief on the pistons for the extra 2 valves on a cx motor..so what you need to do is get a d16z8 swap for your car, then build that up alittle bit and turbo</TD></TR></TABLE>
a d16z what? 8? Shut up now, because you know nothing.
Speaking FROM EXPERIENCE on many cx pistons there ARE 4 valve reliefs. I have done it to my old cx motor, and know someone who has done the same to his, both of them were 5 gen cx motors.
Now, just because you can, does not mean I would reccomend it. If you plan on turbo'ing, I would swap a z6 motor in and call it a day, much better internals (relatively speaking of course) for boost.
Old Apr 9, 2004 | 12:12 PM
cheesepuff's Avatar
Default Re: 93 civic hatchback... pity me.. i have questions. (civicHB0413)
what u should instead of wasting all that money and still be slow is just invest in
gsr motor B18C1 that motor stock alone will give u the same power as that turbo charged motor will thats what u should do
Old Apr 9, 2004 | 12:22 PM
mafioso102's Avatar
New User
Default Re: 93 civic hatchback... pity me.. i have questions. (cheesepuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesepuff &raquo;</TD></TR><TR><TD CLASS="quote">what u should instead of wasting all that money and still be slow is just invest in
gsr motor B18C1 that motor stock alone will give u the same power as that turbo charged motor will thats what u should do </TD></TR></TABLE>
once agian people speaking before knowing. You should spend a little more time looking around, there are some significant #'s being put down on SOHC turbo's. Much better than stock gsr #'s. Hell, my SOHC turbo, with a t3 from a 85 thunderbird @ 7lbs made 173hp and 159ft lbs @ the wheels; all for less than $1500. For what my goals are, a b series motor swap can kiss my ***
Old Apr 9, 2004 | 12:58 PM
92BlackSi's Avatar
Default Re: (mafioso102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafioso102 &raquo;</TD></TR><TR><TD CLASS="quote">
Speaking FROM EXPERIENCE on many cx pistons there ARE 4 valve reliefs. I have done it to my old cx motor, and know someone who has done the same to his, both of them were 5 gen cx motors. </TD></TR></TABLE>
From what I hear both piston types could be had with a CX motor??
Old Apr 9, 2004 | 01:05 PM
92BlackSi's Avatar
here mang https://honda-tech.com/zerothread?id=635580 for the swap.
Old Apr 9, 2004 | 01:09 PM
VX_SOHC's Avatar
Default Re: 93 civic hatchback... pity me.. i have questions. (92BlackSi)
like the link above, search for bauleycivic, he is the mini-me master...that link should show you what you need...but i would recommend just getting a z6 it will be better down the line and it will maybe be cheaper
T-78RX7
26
Sep 4, 2012 04:10 PM
pinks11
Dec 25, 2008 06:47 PM
95CXSLEEPER
20
Jul 6, 2004 11:33 PM
MissLady
22
Oct 23, 2003 07:01 AM
