Help 1992 GS - How to drain Auto transmission fluid? (Cant find drain plug)
Old Apr 9, 2004 | 06:51 AM
FallenLordz's Avatar
Default Help 1992 GS - How to drain Auto transmission fluid? (Cant find drain plug)
Right now It has around 50000 miles, and I dont think anybody ever changed the transmission fluid. I'm having a hard time finding the drain plug for the transmission fluid. (I know where the dipstick is )
Does anyone have a *detailed picture* of where the drain plug is. I searched through different sites and forums, but no luck at finding it!
Been looking under my car just starring and examining the sockets. Dont know which one to unscrew
Please someone help me
Old Apr 9, 2004 | 07:27 AM
3.504's Avatar
Default Re: Help 1992 GS - How to drain Auto transmission fluid? (FallenLordz)
ok, alldata fricken sucks. i couldn't find you a picture. and i dont know where the actual plug is. alldata just says "remove plug, let drain, replace plug." what kinda info is that? anyways, on gm's you have to drop the pan and let the ATF spill out that way. you start by dropping one corner of the pan and work your way around until one side is coming down and you just let it drain. i also dont know where your transmission filter is, but i'm betting its behind the pan just like gm's. so i'd say just drop the pan cause your going to have to if the filter is behind it anyways.
oh yeah, if you've never dealt with ATF before, dont let it spill on anything cause that crap doesn't clean up that easy. ugh... its nasty stuff.
Old Apr 9, 2004 | 11:26 AM
Here is a image of under my car - Can someone tell me which screw should I take off to drain the transmission fluid?
I was thinking it could be the yellow arrow one. Can someone confirm this!
Andrew14
21
Jun 28, 2010 01:12 PM
VtecAdvantage
Mar 30, 2010 10:10 PM
jdmcivicracer89
Aug 2, 2007 03:32 PM
RA61825
May 12, 2004 01:15 PM
