VX rod and piston and deck height specs
Old Oct 26, 2001 | 07:47 PM
fixhondas's Avatar
Default VX rod and piston and deck height specs
According to the AEM engine chart(s) the civic VX (D15Z1) rods are 3.0 mm longer than a DX (D15B2). Can anyone verify this? Are the deck heights the same? Or is the VX piston pin 3.0 mm higher in the piston?
Old Oct 26, 2001 | 07:59 PM
rainforest's Avatar
Default Re: VX rod and piston and deck height specs (fixhondas)
you are right the vx rods are 137mm and the dx's are 134.
Old Oct 26, 2001 | 09:44 PM
fixhondas's Avatar
Default Re: VX rod and piston and deck height specs (rainforest)
what about the piston pins? If the deck heights are the same (3mm higher piston pins) I can use the rods and pistons in my mini-mini-me for a better R/S ratio and less cylinder wall loading.
eg6madness
Apr 19, 2007 06:02 PM
fliptout2
Mar 18, 2006 08:22 PM
Yuleluder
Feb 15, 2006 05:14 AM
fixhondas
Dec 30, 2003 06:08 PM
