What's best way to check for air leaks in ic piping?
Old Apr 8, 2004 | 09:51 PM
calib17a's Avatar
Default What's best way to check for air leaks in ic piping?
A friend told me to seal off at the 90 degree rubber elbow, that connects to the compressor outlet to the ic piping, with pvc cap and use a worm gear to tighten it down. Then I would drill a small hole at the center of the cap insert some type of valved fitting like the ones on a tire, then spray a mixture of dishsoap and water on all the silicone couplings and welded connections on the piping, then pressurize it with a bicycle pump or lightly with an air compressor. You would then look for bubbles that would indicate an air leak. Can I use anything else like some type of gas that would physically show a leak?
Old Apr 8, 2004 | 09:58 PM
Mr. Badlose's Avatar
Default Re: What's best way to check for air leaks in ic piping? (calib17a)
This is something alone the lines that you're talking about:
https://honda-tech.com/zerothread?id=691168
Old Apr 8, 2004 | 10:09 PM
calib17a's Avatar
Default Re: What's best way to check for air leaks in ic piping? (Mr. Badlose)
Yeah that's pretty much the same but as far as some type of gas how about using co2? Any ideas on type of fitting for c02 cartridge?
blackeg
Jul 31, 2012 04:37 AM
freeplay
Jan 18, 2003 09:34 AM
Snafu-Si
Aug 10, 2002 08:02 AM
DamonBoost
Jun 24, 2002 06:03 PM
Muglit
Mar 31, 2002 03:25 PM
