help.. cant take out rear mount
Old Apr 8, 2004 | 07:52 PM
wizzards581's Avatar
Default help.. cant take out rear mount
how do i take out firewall mount?? do i need to take the motor out???
i need to change mounts to new ones... im stuck! has anyone done this?? with mtor stil in:
Old Apr 8, 2004 | 08:27 PM
garados's Avatar
Default Re: help.. cant take out rear mount (wizzards581)
i would try to loosen the other torque mounts and jack up the front of the engine in an effort to swing the motor/tranny forward enough to squeeze the rear mount out. I dunno if that would do it or not since I did my inserts while the engine was out. Good luck, though
Old Apr 8, 2004 | 08:40 PM
tilt's Avatar
i did mine when i swaped the clutch. i would try supporting the engine with a jack to take the weight off the mount, and see if you can work it out. if not you will prob need to take off the mounts that connect to the tranny and lower that whole side a little. gl
Old Apr 8, 2004 | 08:51 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">how do i take out firewall mount?? </TD></TR></TABLE>
you only have to all 4 bolts that hold the bracket to the mount
and the 3 bolts for the mount itself
and then you should be able to wiggle, the mount and bracket, out
note: if you have the intake manifold brace still there, it will need to be removed as well
Old Apr 8, 2004 | 09:23 PM
Sprayin DC4's Avatar
yeah
saemoonyang
11
Nov 3, 2011 12:33 PM
Razr2
18
Mar 15, 2008 08:59 PM
Del Sol on Steroids
Apr 13, 2007 04:23 PM
p1driftfiend
Jun 3, 2004 06:37 AM
tylerdurden
Jul 6, 2003 03:59 PM
