Removed dash having problems help.
Old Apr 8, 2004 | 04:59 PM
CB_ejcoupe's Avatar
Default Removed dash having problems help.
Well I bought a 97 4 door gsr with a cut dash harness, so i took the dash out my car today so i can take out the hacked up harness. The problem i am having is, I cant take the dam climate control off, What is needed to remove the climate control. Need help.
Old Apr 8, 2004 | 06:35 PM
GotGSR's Avatar
Default Re: Removed dash having problems help. (CBtech)
there is a black coated wire underneath the passenger side of the dash that attaches to a little white thing (i don;t know how to describe it) It runs from the center console....the heat control pulls it.
If you cant find it, have a friend move the temp. lever back and forth and you should see it moving.
Old Apr 8, 2004 | 07:02 PM
CB_ejcoupe's Avatar
Default Re: Removed dash having problems help. (GotGSR)
Ok i took that off and now i can change the harness thanks
Old Apr 8, 2004 | 07:27 PM
GotGSR's Avatar
glad i could help
Old Apr 8, 2004 | 09:38 PM
SPLNRSX's Avatar
just got done replacing the complete lower dash harness on a 95 gsr. It was a pain the ***. The air mix control cable is a bitch gettin back in to control unit.
Code Blue
Oct 17, 2007 10:47 PM
StOnErTuNinG
Northeast (Sales)
May 5, 2007 05:31 AM
chitownrida
Feb 22, 2007 12:38 PM
Linh.
Aug 1, 2006 07:38 PM
Zoso1977
Nov 6, 2004 10:57 PM
